Timing chain cover "lip"
Discussion in 'Gen 2 Prius Main Forum' started by Prius92, Nov 27, 2024.
  1. Prius92
    Prius92 Active Member
    489
    110
    Iowa
    Is this lip or shelf on the inside of the edge of the cover supposed to serve as a "guide" of where to place RTV?
  2. Mendel Leisk
    40,498
    Repair Manual info, if it helps:
  3. mr_guy_mann
    mr_guy_mann Senior Member
    3,948
    1,901
    NJ-USA
    That trough is there to "collect" the RTV that squeezes out as you tighten the bolts down.
    If you just have two flat surfaces with even edges, the "excess" RTV will form a string that can easily pull off. Then that string will wind up in the oil pickup.
    The trough provides more surface area for the excess RTV to stick to so it can't come loose.
    More of a pain to clean up on a reseal, but less chance of engine problems.
