Timing Chain Cover Oil Leak 2013 Prius Plugin
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Greg Kaiser, Aug 27, 2016.
  1. Greg Kaiser
    Greg Kaiser Junior Member
    33
    Santan Valley Arizona
    Bought a used Prius 2013 Plugin in Mar. 2016 43k mi.. I do all the maintenance on my cars so I ran it up
    on the ramps to get a look under the oil service port. I saw oil up above the port. Got a camera shot
    of the leak. It was a minor leak but was covered under the 60K mile warranty. My car has around 46k mi.
    Took it in and the labor and parts cost was $1350.00. Another friend has a 2013 and bought it new
    and had the same issue at 43k.
    Problem defined by Toyota as Leaking oil thru porous sealant between cylinder block and timing cover.
    Parts Gasket: Cylinder Head, Camshaft Bearing and Water Pump + 3 O rings. Whatever happened to
    fiber gaskets. Maybe they leak more than the gasket in a tube. ?
    Guessing 10 hours of labor.
    Greg
    athlete11 likes this.
  2. Mendel Leisk
    41,901
    There's been a few reports of the cover leaking, usually the bill is higher, $1700+. Not a fun job, in tight quarters. The Repair Manual shows the caulking sequence and torque spec's, seems crazy complicated.
    Josem3 likes this.
  3. xliderider
    xliderider Senior Member
    8,140
    3,277
    Honolulu, HI
    Yep, I started one of those threads.
    Timing cover oil leak | PriusChat
    Mine was detected at 46k, but it was pretty minor. I was quoted the exact same amount, $1700 for the repair, before I reminded them that the car was still under the engine/powertrain warranty. ;)
    Mendel Leisk and Raytheeagle like this.
    52,390
    ouch, that would be a bitter out of warranty pill to swallow.
  5. Raytheeagle
    Raytheeagle Senior Member
    11,266
    15,521
    Bay Area, California
    2019 Prius Prime
    I noticed a slight seepage from the cover early on, but didn't pay much mind to it. Had it at the dealer a couple of years ago at 90 k and they said they would fix it. Would have been $1506 had I not had the extended warranty;). But an example of a dealer being proactive, which on this site is uncommon.
    I do not frequent this dealer anymore though ( they cracked the valve cover on the wife's 98 4Runner and I had to find it before driving off the lot:mad:).
  6. working1
    working1 Active Member
    121
    112
    sigh...looks just like mine. It's out of warranty and not a major oil leak so not paying for the repair. I suspect this is common on most since the area is very difficult to see. Wishful thinking this a design defect and/or assembly error that would trigger a recall? Guess we need to see the engine go up in flames from the leaking oil to get NHTSA's attention.
  7. Raytheeagle
    11,266
    15,521
    2019 Prius Prime
    Wishful thinking. If Toyota says a quart of oil every 600 miles is ok, what's a little on the engine block?
    A couple of months ago I had the "pleasure" of working on my old man's 96 GMC Sierra. Job was to replace the PCV valve. Popped the hood and every surface had oil on it. I asked if it always looked like this ( he's had it since 2004). The response was unfortunately yes:eek:.
    So it could be worse. The breakdown on my invoice was $120 in parts and the remainder was labor. Probably a good multi day endeavor if you DIY. But that would be if the leak gets worse
  8. The Critic
    The Critic Resident Critic
    3,193
    2,333
    CA
    My understanding is that the official procedure involves removing the engine/transaxle from the car (by removing the subframe), but some techs have found ways to perform the repair w/o removing the engine.
  9. Mendel Leisk
    41,901
    Considering this caulking instruction:
    And then this torque sequence:
    Engine removal's maybe not a bad idea. Crazy amount of labour though.
  10. aventador
    aventador New Member
    hanoi
    thank you so much :D
  11. The Critic
    3,193
    2,333
    CA
    I was told that removing the front/rear mounts, the passenger side axle, oil filter housing and one other item, along with lifting the motor, will give you enough room (barely). When mine starts to leak, I plan to give this a try.
    Toyota has a tendency to specify engine removal for a lot of jobs. Control arms and water pumps (on the early 2gr-fe) come to mind. But both can be done w/o engine removal by removing the motor mounts and carefully lifting the engine by a small amount.
  12. Rebound
    Rebound Senior Member
    3,996
    2,645
    Portland, OR
    I plan to give 0w30 a try
  13. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    "Leaking oil through a porous sealant."
    Damn. On a Prius that's only 3 years old?! And only 46K miles? This is really disturbing. Are there incidents like this on all Prius models? How common is it?
    I had some kind of recall on my Camry... involving the camshaft bearing. And that's when they discovered leaking oil through the gaskets. I didn't believe it at first, but the service manager swore up and down, and said it's very common and he sees it all the time. He blames it on "human error", sloppy assembly, etc. He yelled at me, "ALL TOYOTA ENGINES LEAK OIL!" I WOULDN'T HAVE A JOB IF THEY DIDN'T!"
    Are there any other Prius threads about leaking oil? I'd like to read more.
  14. Rebound
    3,996
    2,645
    Portland, OR
    It's not common. But I've known people who had brand new cars fail. Anything can fail. As far as I've seen, Prius is one of the most reliable cars available. They are super reliable, and proven (except, the 2016 is all-new, but it's most likely even better). 46K is well within the drivetrain warranty, so if it's going to fail, that's a good time.
    #14 Rebound, Sep 8, 2016
    Mendel Leisk and Coast Cruiser like this.
  15. Lineen
    Lineen New Member
    Just had this problem with my 2013 Prius with 85,000 miles on it. Took it to dealer for routine service and was told the engine needed to be removed to fix it and the price is $2500! Out of warranty. Should Toyota cover this type of recurring problem?
  16. bisco
    52,390
    welcome!
    i wouldn't bother fixing it, are you seeing oil where you park?
  17. bisco
    52,390
    was your camry made in usa?
  18. Rebound
    3,996
    2,645
    Portland, OR
    You're only 15,000 miles out of warranty so you should ask if you can get some goodwill coverage out of Toyota. The quotation is also outrageously high. The first post in this thread is someone who had a Toyota dealer do the exact same work for $1,350.
  19. Coast Cruiser
    2,267
    2,571
    Yep. Assembled by those good, pot-smoking American workers. The Service Manager told me "every Toyota engine leaks (or will leak) oil due to sloppy human assembly." He then said he "wouldn't have a job" if they didn't leak oil! I couldn't believe the Service Manager would make those statements, especially in the waiting room full of customers. :LOL:
    So I emailed his comments to the head Sales Manager, and to the General Manager, to let them know how their Service Manager is bad-mouthing Toyota products. But then I said (sarcastically), "maybe he's the only honest service guy at Toyota? Maybe what he says is true, and he should get employee of the month! :ROFLMAO:
    Mendel Leisk and bisco like this.
  20. bisco
    52,390
    we've had 7, up to 135,000 miles, with no leaking whatsoever. we treat our cars well, and don't abuse them. i always wonder how cars with problems are treated, but we'll never know. some people who abuse their cars don't even know that they're doing it.
