Timing chain or tensioner?
Discussion in 'Gen 3 Prius Technical Discussion' started by DAVID 4, Nov 16, 2023.
  1. DAVID 4
    DAVID 4 Junior Member
    45
    Slovenia
    I got P3190 - engine power low.
    Could be timming chain or chain tensioner?
  2. Tombukt2
    Tombukt2 Senior Member
    12,193
    2,150
    Durham NC
    You've got a roll around the crankshaft pulley a couple of times and there's some marks that you should be able to see on the cam gears every like ninth time or something around they'll all line up but you have backlash and that's why you have that play You need to turn the engine in the direction that it turns run it around and put the number one piston on top dead center then most of that will be gone and you'll be within spec I'm pretty sure how many miles on your car is the main thing It looks reasonably clean when you rotate it around correctly most of that play will be gone try it
  3. Tombukt2
    12,193
    2,150
    Durham NC
  4. Mr. F
    Mr. F Active Member
    386
    253
    Washington
    Probably a good idea to continue this discussion in your other thread about the same issue so members can easily see what you've already tried.
  5. johnHRP
    johnHRP Active Member
    576
    172
    tally, fl
    Check if the yellow paint is still bright yellow (not overheated). When it is overheated, the color becomes dull. Replace the tensioner if it indeed does not work properly. Some Prius 3 owner has tensioner problems. It is usually rattle a bit in cold starts.
