Timing Chain Replacement (?) Inquiry
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by sciencekit, Mar 14, 2017.
  1. sciencekit
    sciencekit Junior Member
    76
    Norfolk, VA
    2004 Prius with over 300,000 miles... not sure how many over, since in August of 2015 the odometer hit 299,999 miles and would go no further.
    Over the past month, the check engine light has illuminated and the error code read by Torque is P0016- cam crank position error. After searching the forums, I find that 98% of the time it means the timing chain and tensioner need to be replaced.
    Prius seems to run well, except for the extra bit of engine noise and slightly rough cold start. Once warmed up, the little bit of extra engine noise is all that seems to remain.
    The long, short of it, I recently returned from service overseas in the U.S. Peace Corps, and since I have not located a job yet, money is tight. I am moving (driving) from Virginia to Florida in three weeks to stay with family and look for work. How long can I put off replacing the timing chain and components? I understand that it probably has stretched and skipped a tooth, so the timing is no longer perfect. Yet, should I be concerned with the chain breaking, or can I put it off until I have the funds? Has anyone heard of a Prius timing chain breaking?
    Thanks all.
  2. sciencekit
    76
    Norfolk, VA
    One thing I should add is the check engine light has turned off on its own a few times. Other times, I have erased the code and it came back within two days. Currently, it has been on for a week.
  3. William Redoubt
    William Redoubt Senior Member
    1,228
    1,173
    Coronado Island, California
    How do you know the chain needs replacing? Forum votes? Have a look first. Could be the sensor. Or something else. Codes are diagnostic tools. The actual error is a correlation error between two sensors -- that of the camshaft and that of the crankshaft. So there are lots of variables. Things to check first: sensors, connectors, wiring ...
    The best practice is to not defer repairs, if at all possible.
  4. sciencekit
    76
    Norfolk, VA
    I have not checked the sensors, connectors, or wiring yet. Most of the P0016 issues on Prius Chat were resolved only when the chain and tensioner were replaced. I was adjusting my attack to the problem due to the resolved P0016 issue for others. I need to figure out how to test the sensors and wiring.
  5. ChapmanF
    18,503
    There's the variable-valve-timing actuator on the intake camshaft also to think about, since it's the thing that's actually designed to shift the cam position around. Would be worth finding out if it's that rather than the chain and sprockets. (Well, really, the VVT actuator is one of the sprockets.) At least that's something that could be changed without taking the whole timing cover off (but don't let that make it sound easy; if the timing cover stays on, there's a little hex plug that needs to come out for access to relieve the tensioner, in a really evil place). The kind of work that makes you wonder if it would have been easier to just take the whole engine out (at which point the next question is, and just drop another one in?).
    I'm sort of speaking from how cramped the access was in my old Gen 1. Maybe Gen 2 left more room to get to that wretched plug.
    I would really take the time to look up your trouble code in the repair manual at techinfo.toyota.com. (I tried looking it up in my Gen 1 book, which used basically the same engine, but P0016 seems to be a code they added later.) In the manual, each code leads to a whole troubleshooting procedure, sometimes running to several pages, to figure out what's really causing it.
    In a situation like yours where the just-tear-into-it option will be really labor intensive, Frank Westheimer's line (about how a couple months in the laboratory can sometimes save you a couple hours in the library) really comes into focus. Adjusted a little, maybe, to say a week of scraped knuckles could save you $15 at techinfo ... and maybe solve your problem, or not.
    -Chap
  6. edthefox5
    edthefox5 Senior Member
    10,096
    4,834
    Clearwater, Florida
    Alot of work on a way past life engine.May be cheaper in the long run to pull the motor and drop a used motor in it.
  7. sciencekit
    76
    Norfolk, VA
    I wish I had the money to put an used engine in it. Just not in the budget right now.
  8. William Redoubt
    1,228
    1,173
    Rock it till it drops then. It may be quite a while. Toyota's are tuff.
    Bacon_Is_A_Pooper likes this.
  9. b100
    b100 Member
    145
    75
    Netherlands
    Oke, i had the p0016 code also. I had 2 cases. First one was a stuck vvt unit throws p0016 and second was a timingchain worn out trows a p0016 too.
    You can start with a engine flush, to clean the vvt unit and maybe it will work properly again. If it isnt that, then its most likely you chain :(
  10. Patrick Wong
    18,210
    6,512
    Well, how long are you going to put the repair off? I would put that repair high on the list, and minimize use of the car in the meantime.
    300K miles on the odometer - the car has provided more than normal usage, and now needs some repairs if you want to keep it on the road.
    It is unclear whether the Prius engine has an "interference" design, where, if the timing chain breaks, the valves will hit the pistons. If that happens the engine is toast.
  11. jdenenberg
    jdenenberg EE Professor
    3,953
    1,949
    Trumbull, CT
    2020 Prius
    LE AWD-e
    I believe that our 2ZR-FXE engines are interference engines so, as you said, if the chain slips too far or breaks, the pistons will hit the valves which will necessitate a new engine.
    JeffD
    edthefox5 likes this.
  12. edthefox5
    10,096
    4,834
    Clearwater, Florida
    If suspicions are the VVT is clogged I would start with inspecting the VVT filter. Its located under a hex key head bolt right under intake runner #1.
    When I pulled mine for inspection it was really really on there. Took a big breaker bar to bust it loose.
    If you search my old posts , many years ago I did a write up with pictures on the VVT filter.
    But given the miles its probably the chain.
  13. Patrick Wong
    18,210
    6,512
    I agree that 2ZR-FXE is the engine for 3G and current Prius models. However, 1NZ-FXE is the engine model for Classic and 2G.
    m.wynn and edthefox5 like this.
  14. ChapmanF
    18,503
    Out of curiosity, is there anybody on here who has successfully changed a chain with the engine in the car? I've never tried, but it seems like access would be really tight to get the timing cover off, and then cleaning the mating surfaces and sealing it well would take a lot of luck.
    If the work of changing the chain is comparable to the work of an engine swap, then it doesn't seem as persuasive to worry that failure of the chain, in an interference design, might require an engine swap....
    -Chap
    m.wynn and William Redoubt like this.
  15. edthefox5
    10,096
    4,834
    Clearwater, Florida
    I have the service manual and it shows the engine out of the car. Also there's multiple SST's involved and you have to use a wheel puller to get the crankpulley off. Its alot of parts and work and alignment. And if the chain is worn so will the cam sprockets. It would be a real pain to do it in your driveway. Almost less work to pull the engine out. No matter what going to need the service manual.
    The really bad part is you think you pulled it off only to find you messed something up like the tensioners and have to do it all over again.
    Wow.
    m.wynn likes this.
  16. rns502
    rns502 Junior Member
    Finland
    Here are some photos dealing the timing chain replacement.
    Although it the gap between body frame and engine looked tight at first sight, there seems to be plenty of room.
    After the engine mount is gone, the whole engine-transmission unit drops down to give good access the crankshaft damper.
    Some remarks: Crankpulley/Crankshaft damper drop out on its own, didn't need any puller. Only SST you need is universal pulley tool to open 3 waterpump bolts and crankshaft bolt.
    (And hi to all, as my 1st post here.)
    timingchain-old.jpg timingchain-new1.jpg timingchain-new2.jpg timingchain-access.jpg
    #16 rns502, Apr 12, 2018
    DivideByZer0, strawbrad, SFO and 3 others like this.
  17. jklhill
    jklhill Junior Member
    16
    Thanks your the pics.
  18. Mendel Leisk
    41,865
    Here's something on the VVT troubleshooting, from the Repair Manual. Mostly diagnosis involving Techstream, but on page 7 there's something regarding cleaning of a filter:
    • VVT.pdf
      File size:
      130.8 KB
    SFO likes this.
  19. edthefox5
    10,096
    4,834
    Clearwater, Florida
    I have had that filter out before. It’s under intake runner #1. It’s a hex hole bolt. And like most Toyota bolts is extremely tight. Must use a good quality hex tool
