Timing Chain Replacement Interval
Discussion in 'Gen 2 Prius Technical Discussion' started by JeffG, Oct 11, 2006.
  1. JeffG
    JeffG New Member
    94
    Middle Tennessee USA
    I called Toyota a little while ago with this question: What is the interval for changing the timing belt?
    It's the wrong question of course since it is a timing belt and not a chain.
    In spite of that, I was given the standard answer of 90,000 miles or 6 years.
    I ain't buying that. Has anyone been able to get an official and realistic answer to this question from Toyota?
    If not, what are your suggestions? I have 115,000 miles on my 2004 and want to believe I don't need to change the chain. Hell, I'm still running on the original brakes.
  2. Beryl Octet
    Beryl Octet New Member
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(JeffG @ Oct 11 2006, 12:28 PM) [snapback]331184[/snapback]</div>
    I tend to follow the manufacturer's suggestions, I believe this engine is an interference type, i.e., the belt breaks, the valves and pistion attempt to violate one of the laws of physics... I'd go ahead and change it now, unless you are almost ready to sell the car. I'm kidding about that last part, btw.
    <div class='quotetop'>QUOTE(Beryl Octet @ Oct 11 2006, 12:47 PM) [snapback]331194[/snapback]</div>
    I know how to spell piston, but my typing goes to crap after I read the bit about no edits.
  3. ekpolk
    ekpolk What could possibly...
    548
    176
    Pensacola & Vero Beach FL
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(JeffG @ Oct 11 2006, 11:28 AM) [snapback]331184[/snapback]</div>
    Your second line is, I think, backwards. Given your last statement, I'm assuming you're aware it is a chain in the 1NZ. If there's any lingering doubt, here's a snip-out from the first step in the chain replacement procedure:
    Since you apparently asked the "belt" question, I'd assess the answer as worthless with respect to a Prius. I wouldn't worry about the chain unless you've got some indication that it's damaged.
  4. JeffG
    JeffG New Member
    94
    <div class='quotetop'>QUOTE(ekpolk @ Oct 11 2006, 12:42 PM) [snapback]331229[/snapback]</div>
    What indication of damage would there be?
  5. Ari
    Ari New Member
    165
    I'd be surprised if you ever have to change this part! That's the whole point of a gear or chain driven timing design: it should last the life of the vehicle.
    Dealers like to say something rather than saying "I don't know." When we were shopping for our Honda Odyssey, the sales lady said "... and it doesn't have a timing belt so you never need to change it." That of course is false as I found out when I looked at the maintenance schedule. (apologies to galaxee in advance : not all dealers are shady) B)
  6. FBear
    FBear Senior Member
    355
    23
    Maplewood, NJ
    2015 Prius v wagon
    You know the chain is going when you try and do a tune up. Plugs and adjust timing and it runs like cr*p. The chain has probably stretched and skipped a couple of teeth so the engine will run rough.
  7. JeffG
    JeffG New Member
    94
    Tune up a Prius?
    <div class='quotetop'>QUOTE(FBear @ Oct 11 2006, 12:50 PM) [snapback]331235[/snapback]</div>
  8. ekpolk
    548
    176
    2018 Prius
    Two Eco
    <div class='quotetop'>QUOTE(JeffG @ Oct 11 2006, 12:44 PM) [snapback]331230[/snapback]</div>
    Sometimes they will rattle noticeably. This is a common issue with the Nissan/Infiniti VQ series V-6. I owned a G35 that had occasional bouts with rattle on startup. In my case, it was caused by the slight delay in oil pressure to the chain tensioning mechanism. In that context, if it goes away within a couple seconds, it's not indicative of a problem. OTOH, if your chain is stretched (or perhaps it has a damaged link or two), you may hear constant or frequent rattling. In the case of a stretched chain, the rattling is likely the result of the chain tensioning mechanism being unable to keep the now-too-long chain at proper tension.
    All this said, I doubt the 1NZ will have much trouble with its chain, at least I've never heard of this. Chain rattle is one of those things about which there is little mystery when it appears. If you have it, you'll know it. It sounds pretty much like, well, a rattling chain. You won't have to stand there with a technician eying you with that "what asylum did you escape from" look, while you ask, "did you hear that...did you hear that?"
  9. Beryl Octet
    1,293
    Abingdon VA
    <div class='quotetop'>QUOTE(ekpolk @ Oct 11 2006, 01:42 PM) [snapback]331229[/snapback]</div>
    Thanks, I just assumed everything had a belt these days.
  10. ekpolk
    548
    176
    2018 Prius
    Two Eco
    No sweat. Car makers seem to be drifting back toward the chain designs. Another example is the xGR series V-6s which appear in the 4-Runner/Taco (1GR) and the Camry/Avalon/ES350 (2GR) -- they've gone chain too. I'm guessing that the belt designs created two classes of unhappy customers, those who didn't like the high cost of periodically replacing the belts, and those who didn't like the cost of failing to periodically replace the belts.
    Silver Pine Mica likes this.
  11. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    <div class='quotetop'>QUOTE(ekpolk @ Oct 11 2006, 11:55 AM) [snapback]331283[/snapback]</div>
    Great answer! LOL :D
  12. Tideland Prius
    16,155
    I was under the impression that timing chains were maintenance-free lol. Hmm... But really, if a regular engine needs a tune-up at 100,000 miles...... what about the Prius' engine? 2x that?
  13. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    Some engines are designed so that if the timing belt or chain breaks, the pistons and valves will *not* have an unhappy encounter. The Ford 2.3 liter Lima engine (itself forgettable in most other respects) is one example.
    Don't know the engine in our Prii is like that, however.
    Regarding the service life of timing chains...from what I understand, they should last "more or less" the life of the engine.
    But, as the timing chain stretches (even before it jumps a tooth or two) cam timing will begin to go in and out of spec. This may cause some very unusual, and difficult to diagnose, drivability issues, including reduced fuel economy and increased emissions.
    I'd suggest that attending to the timing chain might be one thing to try if the ol' bucket of bolts just isn't running up to snuff.
  14. statultra
    statultra uber-Senior Member
    796
    30
    Edison,NJ
    2001 Prius
    i had a chain on a 1985 toyota hilux 22R 4 cylinder, lasted 456,000 miles no problems, i dont really think ill change my chain on my prius until 600000 miles or so, the engine starts and stops half that time anyway
  15. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    <div class='quotetop'>QUOTE(ekpolk @ Oct 11 2006, 11:36 AM) [snapback]331271[/snapback]</div>
    I had a similar (same?) issue w/the same engine (3.5L VQ V6) in my 02 Maxima. They issued a TSB for this http://www.nissanhelp.com/Ownership/Bullet...3/NTB03-060.htm.
  16. dmckinstry
    dmckinstry New Member
    1,034
    Cheney, WA (Near Spokane)
    Well, in the "good" old days, even with timing chains they would have to be replaced at ~ 60k - 80k miles. Even though the chains were metal, the gear would have nylon teeth, which would break after they got old enough and the chain "stretched" enough. Then the chain would jump a tooth or two, and there'd be no choice but to change the gear and chain.
    Dave M.
  17. BobZ
    BobZ New Member
    323
    Long Island, NY
    <div class='quotetop'>QUOTE(dmckinstry @ Oct 12 2006, 08:45 AM) [snapback]331627[/snapback]</div>
    Nowadays many timing chain set ups like the three used on Cadillac engines have hydraulic gear tensioners to take up the slack and nylon toothed gears have all but been abandoned ;)
  18. JeffG
    JeffG New Member
    94
    This is great information, especially because it tells me I don't need spend money.
    Thanks everyone.
  19. Godiva
    Godiva AmeriKan Citizen
    10,339
    Uh.....never?
  20. Mia
    Mia New Member
    48
    Long Island, NY
    <div class='quotetop'>QUOTE(statultra @ Oct 11 2006, 09:42 PM) [snapback]331495[/snapback]</div>
    456,000 miles???? My god, where do you live and drive for that matter.
