Timing chain slipped with cover off, how do I safely align?
Discussion in 'Gen 3 Prius Main Forum' started by taupehat, Jul 5, 2021.
Tags:
  1. taupehat
    taupehat Junior Member
    42
    17
    Santa Rosa, CA
    Was nearly buttoned up, found a 12mm bolt, thought perhaps it might be the timing chain guide. It wasn't but that's not currently important. I went to double-check the timing and the damn left hand guide popped off and the chain jumped and I think one of the camshafts may have turned.
    Below are the positions of all three sprockets. How can I safely get this back into alignment from here?
  2. PriusCamper
    PriusCamper Senior Member
    11,059
    4,502
    Pacific Northwest, USA
    I don't have much experience with this stuff, but I'm not seeing evidence that timing marks are no longer lined up? Maybe someone else will come along to comment/clarify.
  3. taupehat
    42
    17
    Santa Rosa, CA
    I had the idea of taking the chain off and using the paint marks to see if the cams were at least in alignment, but they were not.
    I'm guessing the next step is let the cam bearings up, rotate them and the motor to TDC, and then bring the cams back down. Tricky figuring out what TDC is supposed to be but I can get a close approximation from the painted links on the chain maybe? All help welcome - this job just went totally pear-shaped on me.
  4. PriusCamper
    11,059
    4,502
    yeah, definitely spend lots of time checking and re-checking before you address. If it's off its only slightly off and the less you adjust it the more likely you'll be successful.
  5. ASRDogman
    ASRDogman Senior Member
    6,061
    3,253
    Take the chains off, plugs are out, right?
    Then rotate the engine slowly until the pistons are away from tdc. Then rotate the cams
    to the respected places. Then rotate the crank to TDC for #1 piston.
    Install the chains. Though I don't think it matters where the chain for the oil pump goes.
    I am not certain about that, I've never seen anyone write about it.
  6. ChapmanF
    15,457
    It's the keyway on the crankshaft itself that you want to rely on for knowing where TDC is, given that you don't necessarily trust the chain position.
    I've made jokes before about why the oil pump drive would also have timing marks, but I don't really know. I've read about other engines, like the Mitsubishi ones with balance shafts, where that chain also kept the balance shafts properly timed to the crank. But as far as I know, this engine just has a little oil pump in front, and I don't think those affect balance much. But what do I know, it's got timing marks, and the manual even specifically mentions them, so maybe there really is some reason.
  7. taupehat
    42
    17
    Santa Rosa, CA
    Looking at it closely I realized there was no real need for panic - the valves and crankshaft were all very close to TDC, so I used the painted links on the chain to get the valves aligned, then about a quarter turn on the crankshaft and Bob's your uncle. Engine is looking much better now :)
    ASRDogman likes this.
  8. ASRDogman
    6,061
    3,253
    Glad it was simple for you! Have you started it???
  9. privilege
    privilege Active Member
    659
    169
    Birmingham
    does it run now?
  10. taupehat
    42
    17
    Santa Rosa, CA
    I'll find out today. Was waiting for the Permatex to dry and also ran out of light before I could get the dust cover and splash guard buttoned up. Fingers crossed.
  11. taupehat
    42
    17
    Santa Rosa, CA
    Started, runs, drove around a tiny bit with no issues (need to top up oil and coolant as expected). No codes so far. Phew!
  12. ASRDogman
    6,061
    3,253
    That's great!
    taupehat likes this.
