timing reseal cover
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by KQHA, Jul 30, 2023.
  1. KQHA
    KQHA New Member
    San Francisco
    2017 Prius c
    Is this a common issue with a Prius, or any Toyota? I have a 2017 Prius C - under 20k miles but was told I needed to fix the timing cover reseal and was quoted $3820. I almost had a heart attack. I am currently researching for a good mechanic with a better quote. They said on a scale of 1 to 10, I was at a 6 for importance of fixing it. I take my car in every 6 months for it's general service and was surprised nothing was noticed at my previous service.
  2. Leadfoot J. McCoalroller
    7,173
    6,718
    Pennsylvania
    2018 Prius c
    I think of it as a common issue with Toyota dealers.
    These engines will weep a tiny amount of oil from the seam at the timing cover. This is true, and it isn't hard to find the stains to prove it on lots of our cars. But the actual amount lost is not worth caring about in most cases.
    As far as the importance of repair? Personally I would put it at about 0.06 on the scale to 10. Dealers have figured it out that these engines will reliably show a wet stain in that one spot after a few years, and they can scare some fraction of their customers into doing a very profitable but relatively unnecessary repair.
    Here's the reality check: How much oil are you actually losing?
    Prove it for yourself. Pull the dipstick at a few intervals and see if you can actually spot a difference.
    Look at the back bumper and back window of the car. Oil leaked out of the engine tends to get stuck in the slipstream and winds up on the back of the car. No oily film on the back window? No loss measured by dipstick? Then your oil leak is not worth worrying about and your dealer is looking to make a mountain out of a molehill.
    You'll want to find another mechanic anyway. We hardly ever need one for our Prius now, but I look at this time as an opportunity to try the small timers and figure out which ones I like while the stakes are low. That way when the car gets older and the dealer is unaffordable, I'll already have history with the neighborhood mechanic.
    KQHA likes this.
  3. Sonic_TH
    Sonic_TH Active Member
    545
    88
    Puerto Rico
    An oil leak in a 2017 Prius C, yeah i don't think so.
    KQHA likes this.
