TINT FOR THE SMALL BACK WINDOW
Discussion in 'Gen 2 Prius Main Forum' started by Blue Hoosier, Sep 24, 2007.
  1. Blue Hoosier
    Blue Hoosier New Member
    83
    Indiana
    Has anybody had trouble getting the small back window tinted? I have had a company say because it's plastic they were afraid to put too much heat on the window, so they wouldn't tint it.
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    it's plastic?! Hmmm.
    When I did my tint I purposely did not tint the lower glass (plastic?) since it was already tinted darker than the upper. By tinting the upper back window it balaced the view out the back.
  3. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    Are we talking about the lower rear window (in the hatch) or the small side window at the rear? If you mean the lower rear window, why would you want to tint it? It's already tinted quite dark from the factory.
  4. Tojo
    Tojo New Member
    47
    Surprise, Az
    The few prius owners I know that have had their windows done have also had the small one done as well (including me.) It is a pain to tint, they are probably just trying to get out of doing it.
  5. Blue Hoosier
    83
    Indiana
    <div class='quotetop'>QUOTE(firepa63 @ Sep 24 2007, 10:11 AM) [snapback]516848[/snapback]</div>
    I am talking about the small back window in the cargo lid. When we tinted the upper (bigger) window 20% it was quite a bit different from the smaller bottom window. They put the tint on that window, but didn't heat it up enough, so it wrinkled a lot. They took it off and said because it's plastic, they were afraid to heat it up any more. Does anybody know if this is plastic?
  6. seasalsa
    seasalsa Active Member
    1,278
    Kent, WA
    <div class='quotetop'>QUOTE(Blue Hoosier @ Sep 24 2007, 07:32 AM) [snapback]516857[/snapback]</div>
    Not sure about the 2008 but my 2004 has glass in that location. It is marked Temperlite DOT-20 same as the side windows. If it has heating elements in it is is glass. Tell them to check the marking on the glass.
  7. Blue Hoosier
    83
    Indiana
    <div class='quotetop'>QUOTE(Tojo @ Sep 24 2007, 10:23 AM) [snapback]516854[/snapback]</div>
    My husband just told me that the small window is glass but it has plastic around it they were afraid it would melt. I think you're right, they are just trying to get out of doing it.
  8. mhawkin1
    mhawkin1 Matt
    102
    Indianapolis
    I had Ziebart make all of the other windows match the small back window. Looks quite nice.
  9. desertbriez
    desertbriez New Member
    376
    we had the lower window tinted right along with the rest of them!
  10. Devil's Advocate
    922
    Las Vegas, Nevada
    Why are they applying heat??????
    Tint is applied with windex and a fil that has been pre-rteated with a moisture activiated adhesive. It its then allowed to air dry for about 2-3 days.
    Lower window tinted same darkness as upper window.
  11. Blue Hoosier
    83
    Indiana
    <div class='quotetop'>QUOTE(Devil's Advocate @ Sep 24 2007, 03:09 PM) [snapback]516986[/snapback]</div>
    That's what they said...I'll ask them. Oh Year, checked inside the car and the driver side back window had two scratches on it. They said it was probably the squeegee. This company has installed tinted windows in our last two vehicles without any problem. We are supposed to take it back on Thursday to get that replaced..I'll ask about the heat then.
  12. desertbriez
    376
    i thought they used a "hair dryer" thingy when applying window tint?????? that's why all the warnings about being so carful around the doors because of the plastic thingy!
  13. Blue Hoosier
    83
    Indiana
    <div class='quotetop'>QUOTE(seasalsa @ Sep 24 2007, 11:13 AM) [snapback]516871[/snapback]</div>
    I know....I must have misunderstood my husband when he told me what the company said.
  14. Devil's Advocate
    922
    Las Vegas, Nevada
    Definetly tint both rear windows, upper and lower. It may not seem like it but if you don't the two windows will not look the same. I had 25% put on the rear windows and the upper and lower appear almost identical.
    Even if they applied heat with some type of hair dryer, or heat gun, it couldn't be that much. Tint is a pretty flimsy and weak material. I can't image heat damaging even a "plastic" window, which I don't believe the Prius window is, and not the tint itself.
    Also, are you getting the little windows in front and the rear done. Make sure they don't tell you they can't. All the windows, depending on state law, can be tinted.
  15. amhobby
    amhobby New Member
    I had all of my widows tinted including the lower rear one. The guy that was doing it insisted it wouldn't look right unless he did it also. He had me sit in the car and look after he had done the hatch window and he was right.
  16. ServoScanMan
    ServoScanMan Member
    262
    Lorena, TX
    I went to WalMart and bought the 'self cling' black tint. ..and yes I applied it the small plastic rear window. :)
  17. dsyoo86
    dsyoo86 New Member
    16
    oh . i got mine tinted. cause i got 10% all around and it was lighter . so i got it professionally done. and they did it .
