Tip for Cleaning Interior Fabric
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by priuscat, Aug 8, 2006.
  1. priuscat
    priuscat New Member
    Wanted to share a tip I received from my local Toyota body shop. I was in a fender bender in my 2005 Prius :( and when the tow truck driver took my car, he got dirt all over the beige tan interior. When we saw it at the shop, we asked if they could clean it. He said sure, no problem.
    We picked up the car later and all was clean except the driver's side fabric arm rest. We mentioned it to the guy and he went back into the dealership and came out with foaming window cleaner. He sprayed the foam on the arm rest, waited a few moments, and scrubbed back and forth with a white shop towel. Sure enough, the dirt came out of the fabric.
    He said the foam in the window cleaner helps pull out the dirt. The fabric is clean and the nap looks pretty good too. He also said that if the dirt's stubborn, let it sit before scrubbing it out, and consider a second application of the foam window cleaner. The fabric dried overnight.
    I've only used this on the tan interior of our 05 Prius. Don't know about darker fabric. Test in an inconspicuous area before using throughout your car. YMMV and all that jazz!
  2. Tideland Prius
    16,122
    foaming window cleaner?
    interesting. I've never heard of such a product lol. How does it look it? Is it a consumer or commercial product?
  3. priuscat
    priuscat New Member
    <div class='quotetop'>QUOTE(Tideland Prius @ Aug 8 2006, 12:01 PM) [snapback]299609[/snapback]</div>
    I had never heard of it myself until I started working in stained glass and it was recommended to me. It's not a wildly different product than regular window cleaner, but it comes in an aerosol spray can instead of a pump and sprays out white foam that clings to vertical surfaces, which is why some people prefer it. You can buy it as a standard consumer product. Here are some that I've found online. I don't recommend any one over the other, but just to give you ideas of where to find it:
    http://www.superiorcarcare.net/mefoglcl.html
    http://www.parish-supply.com/glass_cleaner_aerosol.htm
    Here's another foaming "all purpose" cleaner that I found while surfing, which probably does the same thing the glass cleaner does, but specifically lists upholstery cleaning as a use:
    http://www.midwayautosupply.com/detailedpr...iption.asp?3169
    The key as I understood it from the Toyota guy is the "foaming" action, which somehow magically pulls the dirt out of the fabric. I have the foaming glass cleaner at home already from the stained glass thing, and so I just use that. Don't know what brand that is though. It's some "rebranded" foaming cleaner I bought at a stained glass supply store.
  4. Tideland Prius
    16,122
  5. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Invisible Glass is one such "foaming" window cleaner. At one time I used to get Bon Ami foaming glass cleaner, but I think they stopped making it.
    You can go to a place like NAPA and find Gunk Foaming Glass Cleaner.
    My Dad managed to spill a bit of coffee in my Prius last month on the trip out to the hobby farm. I'll have to try the foaming glass cleaner when I get my Prius back from the shop this week.
  6. richard schumacher
    7,663
    1,038
    United States
    People have reported getting chocolate and lipstick out of Prius fabric using a clean damp sponge. I'd try that first before any chemicals.
  7. BobZ
    BobZ New Member
    323
    Long Island, NY
    Foaming window cleaner has been around for years. Windex in aerosol, Sprayway, etc. I run the prep dept. for a new car dealer and we use general perpose cleaners like Spray Nine, Fantastik , Formula 409 but the mother of all is a probuct called AFTA which is a form of dry cleaning fluid that can actually remove a greasy paw print from a headliner!
  8. jimmyrose
    jimmyrose Member
    646
    Northern NJ
    <div class='quotetop'>QUOTE(BobZ @ Aug 13 2006, 08:19 PM) [snapback]302727[/snapback]</div>
    Can you actually pull negative G's in your Prius? :lol:
  9. jackaroo12
    jackaroo12 New Member
    Phoenix
    this is interesting what was the brand of the foaming window cleaner?
