Tips on battery charging?
Discussion in 'Gen 2 Prius Fuel Economy' started by AndyMartin826, Sep 12, 2007.
  1. AndyMartin826
    AndyMartin826 New Member
    112
    Gilbert, AZ
    Any tips on preserving the battery when parked at work all day? My battery gets to the 6 bars through the drive in, but it seems that when I crank up after the car has been sitting in the parking lot I have maybe 4 bars which go down very quickly, absolutely killing my mileage as I bring it back up. Any tips?
  2. AndyMartin826
    112
    Gilbert, AZ
  3. douglas001001
    douglas001001 smug doug
    222
    Chicago
    <div class='quotetop'>QUOTE(AZTriGuy @ Sep 12 2007, 11:23 AM) [snapback]511353[/snapback]</div>
    Most likely you are going too fast too soon, in stage 1 of warm up the car uses battery to push while the gas engine warms the emissions system.
    So go easy for the first minute.
  4. douglas001001
    222
    Chicago
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,194
    Nixa, MO
    There's quite a bit of hysteresis with the battery SOC and what's displayed on the MFD. Your shut down and start up true SOC are probably nearly identical (there is a bit of a drop immediately at start up). There's nothing you can or need to do to maintain the SOC. And the point above about driving very gently for the first minute or so after start up is on target...during warm up the ECU will restrain the ICE rpm in preference to using the battery until the emissions system is fully warmed up so you'll see a rapid drop in SOC in that initial phase. You can minimize that by driving very gently that first minute.
    Image credit: Wayne Brown http://privatenrg.com
  6. efusco
    19,891
    1,194
    Nixa, MO
  7. dogfriend
    7,512
    1,189
    Carmichael, CA
    I just want to say that graph is very well done. A+
  8. dogfriend
    7,512
    1,189
    Carmichael, CA
  9. efusco
    19,891
    1,194
    Nixa, MO
    Notice that a drop from 55% (5 OR 6 bars) to 54.5% can mean a drop to 4 bars. So it's entirely possible that your shutdown at 6 bars and start up at 4 bars are nearly identical SOC.
  10. efusco
    19,891
    1,194
    Nixa, MO
  11. AndyMartin826
    112
    Gilbert, AZ
    <div class='quotetop'>QUOTE(efusco @ Sep 12 2007, 10:42 AM) [snapback]511415[/snapback]</div>
    Great charts, helps a lot to understand how the state of charge readout works. Didn't realize the the ICE only worked to warm up the engine for the first minute, I thought still helped in the acceleration but knowing that I'll take it little easier during the first minute or two.
  12. AndyMartin826
    112
    Gilbert, AZ
  13. douglas001001
    222
    Chicago
    <div class='quotetop'>QUOTE(AZTriGuy @ Sep 12 2007, 02:35 PM) [snapback]511479[/snapback]</div>
    You can watch the consumption screen to figure out when its over, you'll get a noticeable jump up when it is done if you're rolling slowly, also btw this is the point when you can enable ev mode.
    If you have a scan gauge, watch ign, when it flips to positive from -10 you're through it.
  14. douglas001001
    222
    Chicago
  15. efusco
    19,891
    1,194
    Nixa, MO
    If youi stomp the accerator hard enough the ICE will rev higher and give more power, but you're pushing it into a very inefficient range doing that.
  16. efusco
    19,891
    1,194
    Nixa, MO
  17. darelldd
    6,059
    389
    Northern CA
    <div class='quotetop'>QUOTE(efusco @ Sep 12 2007, 10:00 PM) [snapback]511758[/snapback]</div>
    Not to mention polluting more.
  18. darelldd
    6,059
    389
    Northern CA
