Tips on glare for vent?
Discussion in 'Gen 4 Prius Accessories and Modifications' started by JayGen4, May 16, 2020.
  1. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    Vents have that chrome tip and I hate the glare. Ideas? Kinda tiny to wrap but maybe not impossible. Sharpie? No thanks. Spray paint? Hard area to paint. Can I remove just the chrome tip? Scared to force it. Can't find anything online
  2. Mendel Leisk
    38,730
    Matt black Plastic-Dip?
  3. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    How hard is that going to be to apply safely inside my car? Sounds... Impossible
  4. Mendel Leisk
    38,730
    There's a paint can version, but not sure how uniform that would end up. Removing parts and spray application looks pro.
  5. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    I guess I'd have to remove my dash, hope the vents inside are removable and tape off everything that isn't the chrome trim.
    I might go about it with some hand paint. I wish I could remove that chrome tip. I might but I'm not sure and can't find that info online.
  6. Kenny94945
    Kenny94945 Active Member
    784
    400
    Sausalito
    2016 Prius v wagon
    I am not sure if just the chrome can be removed and then painted and reinstalled.
    I would try tape or wrap first.
    You Sharpie idea doesn't sound too bad.
    Taping around the chrome and painting with a lacquer and paint brush may be a good option.
    Spray painting in place...yes that is a big production...air brush option desirable.
    Good luck with your project.
    JayGen4 likes this.
  7. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    I'll see about the wrap. I'll ask my guy. And maybe I'll try prying it a little but I obviously don't want to break it.
  8. Mendel Leisk
    38,730
    Post some pics?
  9. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    Once I figure it out or what? Or of the glare? The glare is hard to catch but when it's bad, it's kinda bad. Not as bad as the other parts of the dash at their worst but maybe half as annoying.
  10. Mendel Leisk
    38,730
    Of the items you want to coat.
    I guess the edge of these for example:
    #10 Mendel Leisk, May 17, 2020
  11. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    Just the tip where you'd touch to adjust the vent angle. The perimiter of mine are actually just a flat black (thank goodness)
  12. Mendel Leisk
    38,730
    I might try a can of plasti-dip, with a small (disposable) foam paint brush. Just float it on. Practice on something first. If you don't like it you can peel it off.
    #12 Mendel Leisk, May 17, 2020
  13. JayGen4
    JayGen4 Member
    156
    79
    Sacramento, CA
    Interesting idea. Curious how the finish would be if painted on. Might be worth a try. I'm also a little worried it would peel off all too easily but I'm not familiar with that stuff at all. Never used it but I'm somewhat savvy with spray paint.
  14. Mendel Leisk
    38,730
    It was often used to coat tool handles; ads showed plier handles dipped into the can, so fairly durable.
    JayGen4 and krmcg like this.
