Tire blowout. Am I liable to pay for it plus damages?
Discussion in 'Gen 3 Prius Main Forum' started by RaZa, Oct 31, 2012.
  1. RaZa
    RaZa Member
    480
    93
    Had a tire blowout last night driving on a backroad. Was only going about 35 so nothing bad happened. I was just driving down the road and then a horrible noise like I hit something. I drove around the area twice and nothing to be found on or in the road. The drivers side rear tire just went. Unfortunately the road also put a nice scrape on my 17" rim which sucks.
    So I dropped off the tire this morning and the service department says there's no coverage on the tire or rim damage. Really? Is this correct?
  2. car compulsive
    car compulsive Active Member
    741
    274
    Michigan
    Tires are not covered under the car manufacturers warranty, but by the tire maker - but only if the problem is caused by a defect. If you ran over something which caused the blowout, the tire and wheel problem is your responsibility. Some dealers sell additional tire & wheel warranties which would have covered this. You may be able to make a claim on your auto insurance, but the cost is likely to be less than your deductable and the claim may raise your rates. A tire store would probably be your best option to replace the tire and polish the scrape out of the wheel. Sorry...
  3. wjtracy
    wjtracy Senior Member
    11,361
    3,606
    Northern VA (NoVA)
    Glad you are OK!
    What tire brand would blowout?
    Do you think Pressure was too high (for max MPG)?
    Did the service dept see a puncture in the tire?
    The only blowout I ever had was on my bike, hit the base of broken beer bottle with a shard sticking up.
  4. Judgeless
    Judgeless Senior Member
    1,821
    257
    Cleveland, OH
    If you make your car hit something that causes damage to the body, windshield, tires, underbody, shocks and many other things you are at fault. Only items that fail do to a manufacture defect are covered by the manufacture warranty.
  5. ny_rob
    ny_rob Senior Member
    1,968
    813
    L.I.- NY
    Just last week I saw a service truck with "Mobile Rim Repair Service" painted on the side.
    There's probably someone who offers this service in your area too.
  6. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    Let me guess, you are rolling on the Toyo Proxes A20?
    WE0H likes this.
  7. RaZa
    RaZa Member
    480
    93
    Yeah toyo tires. stock 17 inch ones on a prius five. otherwise i don't know exact specifications.
    I did not hit anything. The hole that blew out is literally on the sidewall. As for psi, I keep them pretty much at the stock specification
  8. F8L
    19,011
    4,083
    50
    Grass Valley, CA.
    The OE Toyos are notorious for weak sidewalls and defects that cause blowouts. :( They are SUPER fuel efficient though. LOL
  9. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    If the blowout is in the sidewall and there are no signs of damage from hitting something, you might be able to get compensation for the tire from the tire company. They typically won't cover any other damage such as your wheel.
    As mentioned earlier, there are wheel repair services. As long as the wheel damage is cosmetic instead of structural, it can be fixed and painted to look like new. Unless you have chrome wheels, then you are hosed.
  10. WE0H
    WE0H Senior Member
    3,247
    528
    Throw out those dangerous Toyo tires and buy some Michelin's. Your rims will thank you. With the reputation of those Toyo's having sidewall failures I just can't imagine why Toyota would use them. It's a serious safety issue. Think if that tire let go while you were on a ramp running higher speeds or on a freeway maneuvering around a big truck. You might not be here today to tell us your story :( They are dangerous and should not be on a car.
    Mike
  11. RaZa
    RaZa Member
    480
    93
    rim damage is $125 to fix. seems steep but isn't everything now-a-days? i talked to the sales manager so far. he's going to look into it. very nice people at toyota of orlando. everyone there is very nice and approachable. i can also try talking to the owner if nothing pans out.
  12. RaZa
    RaZa Member
    480
    93
    Thanks for the heads up. Sucks that I'd have to spend $1000 for new tires
  13. WE0H
    WE0H Senior Member
    3,247
    528
    See if those people at your dealer can do something to get you riding on new safe tires. They must know about the safety issues those Toyo tires have. This thread makes me wonder what happened to that fellow in Winchester Kentucky who ordered his Five Plus Perf when I ordered my car and our cars were on the same ship. We chatted for weeks until one day he went silent on the forum as well as personal emails. His car had Toyo's. I don't recall his name at the moment but he was the guy who worked at the Camry factory north of Lexington. He was very chatty on emails and the forum until he just disappeared one day. I fear he had a tire issue and is no longer with us :(
    Mike
  14. RaZa
    RaZa Member
    480
    93
    did you specify different tires when you ordered your car or change them after?
  15. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    I am getting nervous with my Toyo A20s.:cautious: Running 44/42 PSI, hopefully that helps with the sidewall issue.
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    If you really believe the tires are unsafe then file a complaint with NHTSA. Here are a few sites from a quick search for Toyo blowous:
    Posts tagged "Tire Blowout" | Phoenix Tire Defect Attorney Blog
    Toyo Tires Recalled | Defective Product Lawyer Florida
    TOYO Tires Reports
    The same search for Goodyear blowouts returned quite a few hits as did Michelin. I suspect every tire manufacturer has many postings about their tires blowing out.
    Everyone is quick to point to overinflation as the cause for a blowout. Underinflation is more likely because the additional heat weakens the tire. It seems OP probably has 34psi in a tire rated for 51psi.
  17. WE0H
    WE0H Senior Member
    3,247
    528
    Prius Two, Three & Four come with 15's and the Plus Perf comes with 17's so they take off the 15's in port, where all accessories and some options are installed, and install Michelin's on the Plus wheels. The Five comes in on 17's and Toyo's and the installers take those off the factory Five 17's and put them on the Plus 17's. Regular Fives go from port wearing their 17's with Toyo's and ship to the dealers.
    I was so damn happy to learn that, otherwise I would have had my tires changed before I took delivery. Some will say this manufacturer and that manufacturer has had issues, but those specific Toyo's you have are a serious safety issue, not the MXM4 Michelin's that the Plus Perf gets. Obviously there are other brands/models of tires that are proven safe and reliable.
    I hope Orlando Toyota will work with you to get you into a new set of tires either no cost or very discounted. I know they are nice people to work with as I first spoke with them about ordering my car and later went with a local dealer up here because of the low price they offered.
    Mike
  18. subjective
    subjective Member
    203
    30
    I am of the opinion, based on past experience and failures, that most OEM tires are substandard, that they should be immediately replaced with an upgraded tire for safety and reliability reasons. I changed out the OEM Yokohama tires on our Prius for Michelin LRR tires at 500 mi and have no regrets. Toyota and all manufacturers should have to assist in these upgrades, especially since they are responsible for installing substandard tires on new cars. The manufactures pay low prices for these OEM tires, but if one or more blows you have to pay an unreasonably high price to replace them. So I believe that you are best advised to immediately change them out for a quality tire with a useful warranty and road hazard insurance.
  19. Jonny Zero
    Jonny Zero Giggidy
    1,388
    352
    Austin, TX
    How many miles you have on the tires before this?
  20. Mike500
    Mike500 Senior Member
    2,593
    766
    My Prius"v" two came with 16 inch wheels and Michelin A/S LRR tires. I'm glad that I did not get Yokahomas or Bridgestones.
    For years I've had cars with Yokahomas and replaced tehm with the same. They wore out more uickly than most, and I had quite a few failures.
    I hope that the Michelins are better.
