Tire Bulging
Discussion in 'Gen 5 Prius Main Forum' started by theRob, Oct 6, 2024.
  1. theRob
    theRob Member
    98
    112
    2023 Prius
    I hit a pothole today and now one of the tires has a little bulge. I’m going to replace it with a new one. I have the Toyo Extensa A/S II A. I got the car in April of 2023 and the car has about 6.7k miles on it. Will it be okay to just replace the 1 tire? I measured the tire tread depth (see below) and seems like the rear passenger has barely any wear. According to this site
    Details for Toyo Extensa AS II | Napa Tire & Wheels Napa, CA
    the tire depth is 9/32"
    Front Passenger (tire with bulge)
    Front Driver
    Rear driver
    Rear Passenger
    #1 theRob, Oct 6, 2024
  2. BiomedO1
    BiomedO1 Senior Member
    2,725
    1,455
    SacTown, Ca
    Yep; put the new tire on the drivers side front - that's usually the one that wears the fastest. You may also want to skip a rotation; only rotate the passenger side. Leave it there for 10K miles, then continue the 5K miles rotations. That should pretty much even out all 4 tires.
    Hope this helps...
    theRob likes this.
  3. Gokhan
    Gokhan Senior Member
    5,635
    2,224
    Paramount CA
    Most importantly, make sure that it is identical in brand and model to the original tires. Once the dealer installed the P-metric Toyo (A29) instead of the ISO-metric Toyo (A41) on my previously owned 2020 Prius Prime XLE. They corrected it when I saw it. My 2021 Prius Prime Limited has Dunlop tires.
    theRob likes this.
  4. theRob
    theRob Member
    98
    112
    2023 Prius
    I ordered from tirerack.com it’s the same exact one. Thanks!
    #4 theRob, Oct 6, 2024
    Gokhan likes this.
