Tire Gauge recommendation
Discussion in 'Prius c Care, Maintenance and Troubleshooting' started by UnSurreal, Apr 25, 2012.
  1. UnSurreal
    UnSurreal Junior Member
    38
    16
    Waterloo Ontario
    Hi guys,
    Can anyone recommend a good tire gauge - I picked up a digital one last night from Canadian Tire and it was beyond horrible. I don't mind paying for it online. Thanks.
  2. tlhamon
    tlhamon New Member
    30
    Flat Rock, MI
    Best I can say is just find one that is accurate. I have been using the same one for almost 20 years because I know it is accurate. It was just a relatively cheap plastic dial type. The stick versions are very inaccurate. Just get one and take it someplace that has a known good guage and compare it.
  3. Mendel Leisk
    38,726
    I've tried a decent digital gauge, basically just to test my others. That said, a good quality, pencil type can't be beat imho. As long as it's got the pressure range you need, and is easy to seat on the valve (this can make/break the gauge value, I have one lemon), they never break, are dependable.
  4. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I bought an AccuGauge analog tire gauge with a 0-60 psi scale in order to be able to read the 40 psi I run more precisely. This gauge also has a pressure release button so you can release air without having to remove the gauge.
    You can find one on Amazon or Ebay.
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    I use one like this.
    Auto Meter 2343 Auto Meter Tire Pressure Gauge
    It is small, easy to read and has the pressure release button that some like to use. Much easier to use than a pencil style gauge. You can find cheaper versions for less than $12 at most auto stores. I've had bad luck with digital gauges. They usually last a year or so then break.
    sdtundra likes this.
  6. TruSound
    TruSound Member
    246
    32
    The 818
    I've been using a similar style like the one F8 suggested...I purchased it back in the late eighties for use on motorcycles, very accurate and still in use today. Snap-on
    TPGF60, Tire Pressure Gauge, with Hose, Dial-Type, 5 to 60 psi
    Whatever you do don't buy digital made by Slime, it's a good looking gauge but highly inaccurate.
  7. KK6PD
    KK6PD _ . _ . / _ _ . _
    4,003
    944
    118
    Los Angeles Foothills
  8. NYPrius1
    NYPrius1 Active Member
    1,181
    125
    Middletown, NY
    About a month ago, consumer reports did a report on them. Check it out.
    kenoarto likes this.
  9. KK6PD
    4,003
    944
    118
    URL Link?????? :confused:
  10. ftl
    ftl Explicator
    1,812
    790
    Long Island NY
    It's in the May issue, page 49. Can't view it on line without a sub.
    Top ratings were:
    Accutire MS-4400B $11
    Accutire MS-4021B $10
    Both digital.
    Prismart and kenoarto like this.
  11. UnSurreal
    38
    16
    Waterloo Ontario
    Thanks everyone and ftl - I'll check those out.
  12. XRinger
    XRinger Member
    201
    47
    Woburn, MA
    I've been using the Accutire digital gauge from Sears for 5+ years and the battery is holding up.
    It's been found accurate when checked against a few other gauges.
    I like the gauge so much, I give them as gifts to my family. :D
    It's a good gauge to double check that my compressor gauge is still correct.
  13. Silver bullit
    Silver bullit Right Lane Cruiser
    608
    210
    San Diego, California
    I have one like this made by Slime. Got it at an auto store. I like the pressure release feature. Sixty PSI is a good range for my use which is about 40 PSI. My understanding is that guages are most accurate in the mid range. As with any digital or analog guage make sure it doesn't get dropped or banged around in a toolbox. That could cause it to get out of calibration.
  14. sdtundra
    sdtundra Senior Member
    1,314
    193
    Sacramento, CA
    Have one just like F8L that I keep in the car. It's accurate from others I've compared it to.
  15. Iconn127
    Iconn127 Master Diagnostic Technician
    44
    Cameron Park, CA
    i as a toyota technician will only use amflo 150 tire inflator/gauge
  16. Ruy
    Ruy New Member
    Portugal
    Accutire Digital Tire Pressure Gauges receives top ratings from Consumer Reports Magazine.
    The Accutire MS-4400 B topped the Ratings. They are very accurate on testing, so I believe in the results of the test.
    Tire Gauge | Facebook
  17. XRinger
    XRinger Member
    201
    47
    Woburn, MA
    Sears had the Accutire MS-4021B back when I got mine. It's been mucho years and it's still working great..
  18. Mr Gee
    Mr Gee Member
    88
    30
    Australia
    I'm using this gauge. Saw it used by rally drivers on the WRC. so it must be OK
