Tire grooves get small little rocks.. should I remove them ??
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by szgabor, May 6, 2013.
  1. szgabor
    szgabor Active Member
    993
    175
    Oceanside NY
    My tires getting small little rocks embeded.
    Wondering if it is usefull advisable to remove them ...
    I am trying to remove them with a small hook looking thing avoding damaging the tire iteself.
    But anyone has any idea if this is a good idea or bad or leave alone .. not sure.
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    If you remove them more will show up anyway. There is nothing wrong with leaving them in.
  3. szgabor
    993
    175
    Oceanside NY
    Thanks.
    I was thinking that those things must reduce breaking and acceleration (rubber not sticking as before). Especially on wet surfaces this must have some affect.
    But will leave them alone then.
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    If I have the time I remove them. I don't know that they will significantly affect traction but they could cause microwear on tread and at the very least they could fling up onto the side of your car while turning. Besides, they make noise and look ugly. :p
  5. szgabor
    993
    175
    Oceanside NY
    Well I do not have the time daily ... but every weekend I check the tires for pressure and then all the visible ones I tried to remove I am not going crazy with it though.
  6. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    That is pretty much all I do. If I see a big one I may stop and remove it. Otherwise it happens when I am cleaning and checking air pressure.
    mtbiker53 likes this.
  7. FranklinS
    FranklinS Ach crivens ye scunners!
    190
    94
    Eugene, OR
    I usually remove them during cleaning. I remove them as part of a safety check because nails can often mimic the look of small rocks.
    Kit Shah likes this.
  8. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    If you get enough of them and leave them in for winter maybe they would be like studded tires, sort of. :D
    Kit Shah, fuzzy1, F8L and 1 other person like this.
  9. Mendel Leisk
    38,726
    I have my tires in hand whenever I swap between OEM and snows. At that time I make a point of slowly rolling them along, standing astraddle the tire, with a small flat-blade screwdriver at the ready. I'll flick out the more significant looking pebbles, depending on how ambitious I'm feeling.
    It's really a fishing expedition: every once in a blue moon I'll spot a nail/screw.
    fuzzy1 likes this.
  10. PLSPUSH
    PLSPUSH Active Member
    359
    132
    Tulsa, Okla.
    yes, twice every day
  11. zhutton
    zhutton Junior Member
    85
    Staffordshire, UK
    When the wheels come off ill make an effort or if I get one that is huuuuuuuge and clicks on the road, then i always stop and get rid of it.
    They're resurfacing the roads by me anyway so for the next few months it'll be hell!
  12. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Get a good coat of wax on the lower portion of your car so the tar doesn't stick as well!
  13. fuzzy1
    10,170
    ... or a shard of glass.
    During seasonal tires swaps or tire rotations, I always perform this same inspection. About half the time I also flick out most of these rocks, but it also feels like a waste of time. Leaving them in does not increase the amount of rocks found next time.
  14. Zeus661
    Zeus661 Junior Member
    36
    Fill the groves in with silicone then you won't have rock getting in them.
  15. szgabor
    993
    175
    Oceanside NY
    If you fill them with silicon, where would the water go ??? I thought that was the point of the grooves in the first place I mean even in F-1 the rain tires has grooves for that reason..
    OK you may just accidentally missed the smiley :sick:
