Tire keeps leaking, where to look next?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Solkre, Feb 23, 2012.
  1. Solkre
    Solkre Junior Member
    Goshen, IN
    I bought a used 2006 Prius and after a few months the TPMS went off, and I filled the low tire. Then it went off a few weeks later, and again and again. I got the tire looked at. They cleaned the wheel and the tire and re-sealed it and rebuilt the valve for the TPMS. It still leaked. Then I got a new tire on it completely, and again the TPMS was rebuilt. IT'S STILL LEAKING!
    They told me they even put the tire completely under water, and saw no leak (bubbles). What could be going on here, do I have a bad wheel (rim?)? Is there anything else I should be looking for?
    It's driving me crazy. Good news is everything else on the car seems fine.
  2. fotomoto
    fotomoto Senior Member
    5,602
    3,781
    So. Texas
    Yes it is possible for the wheel itself to leak; usually from a crack. Cold weather also lowers pressures. What pressure do you set the tire for normally?
  3. Solkre
    Goshen, IN
    They came at 40psi so that's what I kept using. The other 3 tires don't have an issue.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    If it leaks it should bubble, unless the leak is associated with stress. It's possible that you have a crack in the wheel that only opens under load, such as cornering.
    Have you tried another tire store?
    Tom
  5. edthefox5
    edthefox5 Senior Member
    10,096
    4,809
    Clearwater, Florida
    There not Goodyear Integrities is it because if so thats your problem.
