Tire noise after 15k service
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by kenp11, Dec 21, 2014.
  1. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    Anyone experience louder tire noise fater 15k service? It sounds like snow tires or wheel bearings. Tires do not look like they are out of balance or alignment. OEM tires.
    Also with sharp u-turns there is a rubbing noise. Are these the "rubber mount stop" making these noises?
  2. Yakoma
    Yakoma Active Member
    470
    122
    ATL-ish
    If you had it serviced somewhere, take it back and tell them to make it right.
    If you did it yourself, could it be that you had different spec tires on front and rear and they are now rubbing after tire rotation?
    Possible if you had significant or uneven wear on the rears you are now hearing that on the front.
  3. xliderider
    xliderider Senior Member
    7,869
    3,116
    Honolulu, HI
    You can't see/tell if your tires/wheels are out of alignment/balance by looking at them. Do you drive on poorly maintained, rough roads?
    The noise when making a sharp U turn might be your ABS system pulsing the brakes because the wheels are turning at different speeds in the sharp turn.
    SCH-I535
    49,409
    perhaps they rotated them incorrectly. what brand/model?
    Okinawa likes this.
  5. kenp11
    74
    Orange
    2014 Prius Plug-in
    Thanks all. I took it back to the dealer that did the 15k service. They found a problem with the right rear wheel bearings and replaced it. Glad it was done before my 16 hour trip
  6. bisco
    49,409
    wow, good call!
  7. Susan4ET
    Susan4ET Member
    429
    52
    Central Oregon
    Wow! A 2014 Prius develops bad wheel bearings! I would be inclined to get all your bearing checked to see if a bad lot was used?
