Tire pressure gauge not working with spare tire
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by whataboutbob, Nov 29, 2022.
  1. whataboutbob
    whataboutbob Junior Member
    74
    16
    2010 Prius owner. I bought this tire pressure gauge which works great with the 4 regular size tires but it can't read the spare tire air pressure, does anyone know if the spare tire has the same Schrader valve as the regular size tires?
  2. Tombukt2
    Tombukt2 Senior Member
    12,214
    2,155
    Durham NC
    Yes same valve you should be getting a reading can you touch the center pin and the Schrader valve with the screwdriver and hear air coming out?
  3. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    You might have to take the spare out and flip it over for access to the valve.
  4. fuzzy1
    10,335
    Yes, it does. I read my spare's pressure with the same gauge as the regular tires, and can see no reason why your pictured gauge might not. It has the right head, and a sufficient pressure range.
    Are you not finding the spare's valve (stored normally in the trunk, it is on the bottom side), or are you getting no reading (e.g. flat, no pressure remaining)? Or are you not getting the head onto the valve straight?
  5. whataboutbob
    74
    16
    @Tombukt2 Yes, I heard the air being released when I pressed against the center pin.
    @fuzzy1 The spare tire looks fully inflated and yes I know how to position the head to get a reading :)
  6. bisco
    51,155
    maybe the pressure is too low to get a reading. can you set your compressor?
  7. whataboutbob
    74
    16
    The tire feels solid, not flat in any way, so I am sure it isn't too low and no, I can't set the compressor. This is bizzare. I am buying a different brand and see if it helps.
  8. bisco
    51,155
    maybe the end of the schrader valve is damaged
  9. Mendel Leisk
    40,586
    What kind of gauge? Has it got sufficient range; spare is 60 psi.
    If this is first time you checked it, it's guaranteed to be low?
    When we purchased our 2010, paid full Pre-Delivery Inspection, spare tire was at 40 psi. 12 volt battery was dead as a doornail too *. They tried to hide that...
    That was at Open Road Toyota in Port Moody, the "not so good" guys. :rolleyes:
    Oh, and they said documentation was "included", on the first paperwork. Rewrote it, and "included" morphed into $295 CDN. Were actually miffed when I called them on it.
    Charged $400 CDN for installed block heater.
    And when I asked about Toyota steelies for snow tires, said there were none, since the Prius was a "flagship vehicle". Westminster Toyota helped me out there.
    Lessee, what other dirt have I got. Better shut up... :unsure: They might sue... :ROFLMAO:
    * We bought our cream puff in November 2010. It was dust covered, way back of the show shed. See later, the build date was August 2009. Still it's been champion. (y)
  10. whataboutbob
    74
    16
    Doubt it, I was able to let out air by pressing on the center pin.
  11. whataboutbob
    74
    16
    @under
    Plenty of PSI, up to 100, https://www.amazon.com/dp/B016R9KKCU
  12. Mendel Leisk
    40,586
    Maybe finicky connection. I'm using a few pen-style, and a very cheap digital, all work ok.
  13. bisco
    51,155
    the pin might be good, but maybe the threads are bunged
  14. whataboutbob
    74
    16
    I doubt that, I have only ever used the spare tire once. I plan to bring it to Costco tire center and use their air pump to see if it registers a reading, I will sort this out one way or another.
  15. CR94
    CR94 Senior Member
    2,664
    1,152
    Northwestern S.C.
    What's the minimum pressure your gauge will show? My guess is that the pressure is below that, but not low enough to subjectively seem flat
  16. whataboutbob
    74
    16
    Reading starts at 0 and like I have said before, when I pressed on the tire, it is quite full and far from anything that resembles flat. This is not the issue.
  17. ChapmanF
    17,348
    Tire gauges just aren't anywhere near complicated enough to be playing "oh, this is the spare tire, I'll do something else just to be ornery" games.
  18. jzchen
    jzchen Newbie!
    3,316
    1,020
    Arcadia, CA
    Sometimes I find a similar issue. My issue is that between measuring the pressure measured changes, or the (digital is what I use) gauge may not read anything.
    I suspect the valve has been installed into the stem too tightly, or it’s somehow different dimension the pin is too deep for the gauge to press it. The best solution I can think of is to have the complete valve stem replaced, or at least remove the valve and re-torque it, replace with a new one….
    EDIT:
    I have one of these but point is there’s a torque spec for the valves and I’m not sure they are all torqued to spec:
    https://slime.com/products/pro-series-valve-core-tool
    #18 jzchen, Dec 4, 2022
  19. RRxing
    RRxing Senior Member
    2,530
    1,806
    NEPA
    I remember the valve stem on the spare had to be moved a tiny bit to get a good reading when checking the pressure because it was really close to the rim. This was when I had both my 2010 and 2017 Prii.
  20. whataboutbob
    74
    16
    Mystery solved! Thanks to everyone for your suggestions and tips. While it still had some air in the spare tire, it was way too low to register. I took it to Costco Tire Center where it is the only place I found with a reliable outside digital pump and even that didn't work until I took the tire to the shop and they told me about the outside pump requiring a minimum of 15PSI to register and mine was below that apparently. This also raises another question as to why the air gauge that starts at 0PSI didn't register anything, the air gauge works after it was inflated to 60PSI.
    jzchen, Mendel Leisk and bisco like this.
