Tire Pressure Gauges
Discussion in 'Gen 2 Prius Main Forum' started by GreenMachine, Nov 18, 2005.
  1. GreenMachine
    GreenMachine New Member
    760
    Vermont, USA
    CU rates the Accutire MS-4000 as the top choice. Highest rating for accuracy but low marks for ease of use.
    Accurate tire pressure seems very important for mpg, but if it is hard to use, I might be less likely to use it enough.
    Anyone using it? Any recommendations?
  2. tochatihu
    tochatihu Senior Member
    9,548
    3,682
    Kunming Yunnan China
    2001 Prius
    I use a lowly $10 Asian import digital gauge, which turned out to be very accurate according to a friend equipped to check calibrations. Sold in blister packs at your favorite variety/auto store.
    Whatever you choose, use it often and remember tire #5.
  3. wrprice
    wrprice Active Member
    415
    308
    Houston, TX
    Four Touring
    I used an Accutire gauge once. It wasn't the 4000, but I'll never buy that brand again -- I got *one* use out of it before it stopped working. Piece o' trash.
  4. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I would like something to keep the pressures at 42/40 at a glance, if I can trust it. As it is I check the tire pressure on Sunday AM.
  5. tripp
    tripp Which it's a 'ybrid, ain't it?
    4,717
    79
    Denver, CO
    I checked my tyres for the first time after getting the car about 3 weeks ago. I too have a cheepo digital gauge. Seems OK but don't have a way to verify it yet. Still, I noticed that my tyres were set to strange levels.
    LSF = 38.5 psi
    RSF = 37.5 psi
    LSR = 37.5 psi
    RSR = 38.5 psi
    First, I have the distinct feeling that my gauge rounds to the nearest 1/2 lb which annoying. I assume that something with more precision is desirable? Second, this seems like a really odd way to set the tyres, no?
    Took a trip up to the gas station and adjusted the tyres to 40/38. Should I check them weekly? I've never paid this much attention to a car before so I'm pretty ignorant when it comes to these smaller details.
  6. wrprice
    415
    308
    Houston, TX
    Four Touring
    Many consumer digital gauges round to the nearest 0.5 PSI, so they have an accuracy of +/- 0.5 PSI. With that knowledge, your readings indicate all 4 tires are "about 38 psi" though it would be just as easy for two to be closer to 39 and the other two to be near 37 -- a 2 PSI difference.
    This isn't rocket science; if you get your tires to read the same pressure using the same gauge, +/- 0.5 PSI accuracy isn't going to kill your mileage. The important thing is to keep your front tires 2 PSI above the rears.
  7. tumbleweed
    tumbleweed Senior Member
    4,067
    690
    Eastern Oregon
    Why? is it just because there is more weight in the front. Or is there some other reason. I have tried with the 2 lb difference and tried it with all 4 the same pressure and I can't tell the difference.
    I did ask this same question in another post today and was hoping to get some different points of view.
  8. GreenMachine
    760
    Vermont, USA
    The CU ratings, in the order of rating are:
    Accutire MS-4000 -- $18.95 at Jazebra.com -- 1/2 lb increments, 5-year warranty--digital
    Accutire MS-4020B -- $19.99 on Amazon.com--digital
    Monkey Grip M8867--digital
    NAPA 90-389
    Monkey Grip M8862
    Pressure Inc. DT-105
    AccuGauge H100X
    Monkey Grip M8854
    Any comments on any of these other brands?
  9. IsrAmeriPrius
    IsrAmeriPrius Progressive Member
    4,333
    Southern California
    That's the one I use. I bought it from Amazon when it was on sale for about $17. I am very satisfied with it.
  10. Brian K
    Brian K New Member
    152
    I recently bought 2 digital tire gauges. One from a bin at a parts store. It didn't last 5 minutes before I tossed it, it couldn't repeat a reading to within 10 psi.
    I got another one that was ordered from a speed shop. It's better and repeats the readings, but rounds off to the nearest 1/2#. It's OK. I do believe it's an Accutire. I wouldn't buy it again. It's difficult to use.
    My favorite is the Drager pressure guage I got 35 years ago. Pretty sure I bought it in Germany. It's got an analog dial and is extremely accurate, very easy to use too. It'll hold the last reading (and the internal pressure) for months, until you press the button to take the next reading. I don't know if they're still made, but if I ever saw another I'd buy it in a heartbeat. It allows one to zero it for the current Barometric pressure to get a true reading. It's a real nice piece of equipment.
  11. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    helps control understeer
  12. jamarimutt
    jamarimutt New Member
    985
    I have a talking gauge that reads out the pressure using a digital female voice. The tire pressure is accurate to 0.5 lb. The gauge also has an LED screen that shows the pressure.
  13. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
  14. GreenMachine
    760
    Vermont, USA
    Now that looks cool as hell if it actually shows the realtime pressure in each tire, not just when a tire gets low. The monitor looks as if it does show actual tire pressure from what I can see.
    The price gives me pause as well as the size of the monitor/antenna. But cool as hell anyway.
    Too bad that can't read on the MFD instead of the monitor.
  15. elrjax
    elrjax New Member
    Jacksonville, Florida
    Brookstone has several models you might want to consider. I just purchased one for $35 that displays the target and actual pressure and uses colors for over/under/on-target pressure.
  16. GreenMachine
    760
    Vermont, USA
    Very helpful everyone, thanks :D
  17. aaf709
    3,862
    2022 Prius Prime
    I've seen Prii with Valve Stem Pressure Gauges. I wonder how accurate they are. Of course, even if they did work you'd still need a tire pressure gauge for inflation.
    Thanks for the suggestions! I need a new gauge.
  18. bookrats
    bookrats New Member
    2,843
    Seattle, WA
    My understanding is that this is basically what the 2006 models are coming with, built in -- a continous tire pressure monitoring system.
    However, a friend of mine mentioned you can get one for less than the ~$400 that the model mentioned above costs. I'll ask him for a reference and post it here.
  19. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    the tire pressure sensors that are on the 2006 only warn if the pressures are low i believe. not sure if it will let you set your pressure limits. the Lexus had something like this and it only let you know if there was a problem if something like 25% below the recommended.
    that means if recommended is 35/33 and you are running 44/42 you will not receive a warning until a tire is at about 27/25? that would be worthless to me.
    the one shown and lets face it, its aimed at professional drivers, taxi's, truckers, etc it allows you to monitor all the tires and has user settable alarms. so you could set the alarm for say 38.
    i only mentioned it because my ex-father in law says that they are the best. he is a IT transit bus driver. i personally have a cheap ($8) digital gauge that is accurate to ½ psi. it reproduces the same reading over and over and i am perfectly satisfied with it. it does require much more work on my part and last summer i aquired a nail and my tire was done to about 15 psi by the time i caught it. i originally posted it because i felt it a bit ridiculous that people were complaining about only having ½ psi accuracy.
    if you want better, you will have to pay for it. period. another reason i mentioned it is because if every PriusChatter knew about the product, i can garantee you some will buy it. probably not a lot, but someone will buy it.
    my next door neighbor bought wheels with those spinner things that light up. after what she paid for those, $400 is nothing.
  20. tumbleweed
    4,067
    690
    Eastern Oregon
    Yes, thank you Dave. I have been thinking the same thing, any car with a 60/40 front/rear weight distribution is going to understeer quite a bit. What I have been unsure of is the effect of less pressure in the rear, it seems that lowering the pressure might actually cause the rear to stick even better thus increasing understeer. However with VSC it may not matter because VSC kicks in and seems to keep the handling pretty neutral anyway. Of course it is also true that with the weight distribution such as it is you wouldn't need as much pressure in the back to carry the weight, even with a full load of luggage.
    This may be a subject for a different topic anyway. Now if I could just find my tire pressure gage, could be time for a new one.
