Tire pressure on 2007 Touring Editon
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by AlphaTeam, Jul 18, 2007.
  1. AlphaTeam
    AlphaTeam Member
    643
    Earth
    I talked my sister in law in to buying a Prius. She got the 2007 Touring edition (Grrrr).
    On my 2006 I do 42/40 for optimum gas mileage. What about the tires on the Touring?
  2. fd143
    fd143 Junior Member
    south fl.
    I run the same pressure as you (42/40) on my 07 Touring.
  3. Y. Zhou
    Y. Zhou New Member
    NY - MA
    I've found that while as a driver I have no problem with high tire-pressures (42/40; 40/38), the ride experience as a passenger is very different. At higher pressures comfort is noticeably reduced, mostly due to increased road noise/vibration and the harsh ride. However at lower pressures (37/35; 35/33) the handling and especially the cornering-performance of the car is noticeably reduced. So I settled in the end for a compromise at 39/37 and I don't repressurize until the tires are below 38/36.
  4. FloridaWen
    FloridaWen New Member
    573
    Plant City, Florida
    <div class='quotetop'>QUOTE(Loail @ Jul 22 2007, 02:39 PM) [snapback]483204[/snapback]</div>
    We are running 38F/36R in our 2007 Prius Touring and it handles well. We did try slightly higher tire pressures in the OEM P195/55 R16's and the Prius started to handle a bit "squirrelly" so we went back down to 38/36 and are staying there with these tires. Our gas mileage is a bit over 50 MPG with 50/50 city/highway driving.
