Tire pressure question on 17 inch tires
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by socal13, Jun 25, 2015.
  1. socal13
    socal13 livin in the foothills...
    262
    86
    Altadena CA
    I have a 2013 Persona with Toyo Proxes P215/45R17 which were original to the car. What tire pressure are you using? Thanks for your input.
  2. dustoff003
    1,371
    335
    Waianae, HI (Oahu)
    42psi front and 40psi rear on my 2011 lift back five
    iPhone ?
  3. Xterra72
    Xterra72 Senior Member
    1,406
    1,658
    I have the 2013 Persona. Same tires. I have mine at 44/42 or 42/40, depending on how much I want to increase the mpg and increase the harshness of the ride.
  4. Siward
    Siward Active Member
    296
    124
    Toronto
    The manufacturer's tire pressure recommendations are on the sicker when you open the driver door.
  5. Mendel Leisk
    38,718
    I'm using 34 psi all 'round, only slightly higher than what's recommended on the door jam decal.
    I had them higher, around 38, but got tired of the extremely harsh ride. Even at lower pressure the ride is pretty hard, but better.
    I noticed little or no mpg drop, and I'm tracking every tank.
    The tires are Michelin Pilot HX MXM4.
  6. OBJ
    OBJ Member
    62
    27
    Stouffville, Ontario, Canada
    I went from what is recommended to 35 psi all around, the ride is a little harsh but ok for me, no mpg drop .
  7. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    Max. sidewall--51psi.
  8. ahmeow
    ahmeow Prius Lover
    366
    70
    North CA
    I got a 2011 with 17" rim, Michelin Primacy A/S. I set all four at 34 also. Not bad. Got 53.8-54 mpg.
  9. Toppcat
    Toppcat Member
    223
    69
    Northern California
    33 frt 32 rear road trips 40 frt 36 rear 52-58 mpg hwy
  10. dorunron
    dorunron Senior Member
    3,318
    1,103
    Houston, TX
    Was running maximum of 51 F 50 R but dropped it back to 45 F 44 R. MPG about the same. but a little smoother ride at lower pressures.
    Door jam says 33 F 32 R IIRC. I haven't looked at the door jam recently, so going by memory...
    Prius rides real smooth at door jam settings, but seems to glide easier with the higher pressures. IMO, find what you like and roll with it.
    17" Michelin Primacy
