Tire Pressure Recommendation for Winter
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Tideland Prius, Dec 6, 2009.
  1. Tideland Prius
    16,445
    Hey, just looking for some suggestions with regards to winter tyre pressures. Obviously i can't use the factory setting because it's not the same tyre.
    I'm currently running Nokian Hakkapeliita R winter tyres. They're set at 42/40 corrected at +20°C/68°F. (IOW, at the present -20°C/-4°F, they're probably at 34/32). The tyre is rated for 50 something PSI so I have plenty of "space" to work with.
    Is it better to run them at a higher pressure or lower pressure? I suppose in deep snow, lower is better but most of the time, the roads will be plowed so I'll be driving on solid pavement (or at worse, compact snow). With the higher PSI rating, is it best to pump the pressures back up to 42/40 at -20°C/-4°F? or leave them at 34/32?
  2. cossie1600
    cossie1600 Active Member
    903
    94
    CT
    Higher, less contact patch, just don't go into the 50s or 60s like the nut job who wants to save .2 mpg
  3. Bob64
    1,540
    93
    Virginia
    The "Max sidewall" rating is not the psi burst pressure of the sidewall. Rather it means that it will support the maximum specified load at that pressure, but if you go above that pressure, it won't support any additional load.
    source: edmonds's myths #10
    Top 10 Automotive Mechanical Myths and Misconceptions
    I don't think tire pressure affects the contact patch too much unless your way under-inflated.
  4. Tideland Prius
    16,445
    So correct them back to 42/40 at the OAT then? Alright. I probably won't do it outside so i'll have to calculate it from 20°C again.
  5. richard schumacher
    7,664
    1,043
    United States
    What's to calculate? Fill them to 42/40 and you're done.
  6. swich2mac
    swich2mac Go Hard or Go Home!
    319
    38
    Franklin, TN
    Is that 42-front and 40-rear?
  7. Tideland Prius
    16,445
    Temperature. The underground garage is at 20°C. Outside, it's -20°C. I would lose 6PSI if I were to set 42/40 in the garage meaning I'm running the car at 36/34.
    I do not know about you but I have no intentions of filling up a tyre outside in -20°C weather.
  8. RodJo
    RodJo Member
    423
    56
    Boston
    "Always check your owner's manual for the recommended tire pressure for your vehicle." (edmonds's myths #10
    Top 10 Automotive Mechanical Myths and Misconceptions) In context, the myth is discussing carrying heavy loads in an SUV, in which case the tire pressure may need to be increased to the max sidewall pressure, which could actually be the recommended pressure for that load.
    Contact patch is related to PSI, regardless of tire pressure -- it's in the "square inch" part. Increasing tire pressure decreases the area needed to carry the load, whereas decreasing tire pressure increases the area needed to carry the same load.
    The recommended tire pressure is a compromise of various factors. I've provided a more detailed discussion elsewhere, but on average, a 1 psi increase in tire pressure causes a 1.2% decrease in tire adhesion on pavement. (Improved Automotive Suspension Testing Apparatus)
    While it is risky to compromise your tire adhesion by overly inflating the tires, winter conditions can change some of the parameters. A couple of extra PSI might be helpful on snow by putting more weight down per square inch (think the opposite of wearing snow shoes), thus helping your tires get to the pavement. So it may make sense to sacrifice a little dry pavement adhesion in exchange for better traction in snow.
  9. FireEngineer
    FireEngineer Active Member
    1,247
    124
    SW-Side of Chicago, IL
    Unless your going through a lot of deep fluffy snow and need floatation above it, go to max sidewall PSI. If your going to fill in your heated garage just add a couple of PSI more and then forget about it.
    Wayne
  10. Tideland Prius
    16,445
    k. I'll bump them back to 42/40. I won't go max sidewall because at 42/40, the ride's stiff enough for me.
  11. wvgasguy
    wvgasguy New Member
    1,255
    185
    a
    comment deleted
  12. FireEngineer
    1,247
    124
    All that padding from the layers your wearing in the cold and your worried about your bottom getting bruised?
    Wayne
  13. Rhino
    Rhino New Member
    460
    U.S.A.
    You can't figure this out by calculations. You have to collect empirical data. The reason is that the tires are not constant volume. The volume probably shrinks as pressure is lost so your PV=nrT sort of equations would not work.
  14. Tideland Prius
    16,445
    I wasn't calculating actually. I was just using the rule of thumb (1 PSI for every 5°C/9°F) for a quick estimate. I really don't want to check the tyres when it's -30°C outside (or -40 as it was yesterday)
    I do not know how your streets are like but ours where it isn't plowed is covered in compact snow that somehow managed to form little hills. It's like riding on a poorly maintained cobble road
  15. Airbalancer
    Airbalancer Active Member
    892
    73
    Cobourg, On, Canada
    So should we go with 42 front 40 rear?
  16. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    I found the handling improves on wet payment with higher pressure so IMO, yes.
  17. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Unless they left the cords out of your tires when they were manufactured, the volume change is not very significant.:D
  18. Tideland Prius
    16,445
    Depends on your tyres. I'm running Nokian Hakkapeliita R winter tyres on 42/40. It's currently above zero during the day and it's fairly stiff for my liking (the bumps are transmitted right into my seat).
    I would hesitate to go higher in the winter because you need more traction (either on compact snow or just glazed asphalt). If possible, I'd try two different pressures (say factory 35/33 and 40/38 or 42/40 and do a braking test on an icy or frosty road and see how braking feel and distance compares.)
  19. Airbalancer
    892
    73
    Cobourg, On, Canada
    I am at 40/38, when I pick up the car the tres were at 29
  20. Tideland Prius
    16,445
    Alrighty.
    Yeesh. I've had the dealer reset the pressures to 32 all around and I quote "because that's what the Corolla uses." The last time I checked, I bought a Prius :confused:
