Tire pressure sensor
Discussion in 'Gen 5 Prius Technical Discussion' started by CruisnGrrl, Jun 12, 2023.
  1. CruisnGrrl
    CruisnGrrl Active Member
    149
    125
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    I had someone ask if my Prius Prime had the tpms aka tire pressure monitoring sensor because their RAV4 doesn’t. I figured others would like this info too. I can confirm that it does and the info can be displayed on the driver side dash.
    I don’t know if it’s only a particular type of sensor or only compatible with Toyota sensors.
  2. Preebee
    Preebee Senior Member
    854
    750
    Midwest
    2023 Prius
    I think all Toyota's have TPMS. But they all don't display the actual individual tire pressures. I hope we have it on the LE!
  3. CruisnGrrl
    149
    125
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    That was another thought. It might depend on trim level if you get to see individual pressures. I'd have been OK with just knowing which tire is too low or high rather than knowing the exact pressure. I don't need to know the actual pressure level when driving.
  4. Trollbait
    11,541
    It's required in the US, but not in Canada.
  5. fuzzy1
    10,167
    After some postponements, TPMS was finally required on U.S. vehicles since model year 2008. If that someone's RAV4 doesn't have it, it must be an older model.
    The individual pressure reading is note required, and many of us have cars with just a simple warning that one tire is low or not reporting.
  6. Trollbait
    11,541
    Or their Canadian;)
  7. fuzzy1
    10,167
    Oops, missed that this time.
  8. PeninsulaPrime
    69
    47
    Washington
    Confirming that individual pressures are indeed visible on the LE.
    daisy555 and Preebee like this.
  9. CruisnGrrl
    149
    125
    Ontario, Canada
    2023 Prius Prime
    XSE Premium
    Is that for the 2021 or the 2023? This post is regarding the Gen 5 Prius (2023+)
  10. PeninsulaPrime
    69
    47
    Washington
    I have a 2023 LE in the US. It has PSI readings, not just 'tire low' warnings. Haven't updated my profile yet :)
    Preebee likes this.
  11. bisco
    49,446
    good to hear, and about time!
  12. Trollbait
    11,541
    The 2016 Camry Se had individual readings, while other trims appeared not to. Not sure why that was. Wasn't like the SE had a different dash.
  13. HACKSAW
    HACKSAW New Member
    Burnaby BC
    2019 Prius
    not on my 2018 C model. Very disappointing!
  14. friyet
    friyet Junior Member
    25
    28
    Madison, Wisconsin
    2023 Prius
    Can you tell me how you are able to display the PSI readings on the dash please for the US model? I've tried to go into the settings but all I'm able to display is tire pressure settings, not display of actual pressure. Thanks - friyet
    daisy555 likes this.
