Tire pressure/short trips and mileage
Discussion in 'Newbie Forum' started by wantaprius, Sep 28, 2008.
  1. wantaprius
    wantaprius Junior Member
    66
    Oregon
    2014 Prius Plug-in
    Ok, I have a couple questions. I have a new 09 Prius and I am wondering if it really will make a difference to put 40/38 air pressure in my tires like I have read.
    I drive very short distances about 1 mile 1-2 times a day. I know this might be bad for mileage because the car wont ever warm up. It has to be better than my Subaru Forester. I only got 20 MPG with this same commute.
    What can I expect. I go down a hill one way and back up coming home. I have 3-4 stop signs each way.
    My question is.
    1. What can I expect to get for mileage?
    2. Will it really make any difference to have my tires inflated to this level?
    (the guy at the tire store kind of gave me a hard time when I asked to get 40/38 in the tires. He went on about the reasons not to. I did try to search but there is a lot of threads with tire pressure in them. Thanks
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Yes it will make some difference, but with trips that short it will hardly be noticable. But your tire life will be better in any case.
    No way you can walk or bike that huh??
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    If you can't walk such short distance then try to advantage the initial downhill portion of your trip. Press the gas paddle gently to gain some momentum and then supplement it with the gravity to gain some additional speed. You should have the ICE on (arrows coming out of it) to warm up, but still should be able to achieve some decent MPG. Coast to the stop signs. By the time you complete this downhill portion of your trip you will have a partially warmed up engine for the second leg. Try to make your stop as short as possible so you don't lose too much of that gained heat.
    Good luck,
  4. expatriot
    expatriot New Member
    30
    usa
    Does tire pressure really make a big difference. If it does, why doesn't the manufacturer recommend a higher tire pressure.
  5. jdenenberg
    jdenenberg EE Professor
    3,852
    1,853
    Trumbull, CT
    2020 Prius
    LE AWD-e
    Toyota is worried about complaints that the ride is harsh so they spec 35/22 PSI in tires that are rated safe at 44 PSI cold.
    Running 42/40 as I do has benefits. First, it does noticeably, but not dramatically, improve MPG. If you have the OE Goodyear Integrity tires which have very soft sidewalls, higher psi will reduce the scrubbing of tread edges in turns thereby extending tire life. It also reduces the high speed instability of these tires (a noticeable side-to-side wobble).
    Better tires are a significant improvement for a Prius. I now have 130,500 miles on mine and am well into my third set of tires. Both the Michelin "Energy Saving" and my present Nokian WRs were/are significantly better than the OE Integrity tires in all aspects with the WRs also greatly improving traction in wet/cold weather. See the attached zipped Excel spreadsheet for detailed data on my experience.
    Enjoy your new Prius.
    JeffD
  6. wantaprius
    66
    Oregon
    2014 Prius Plug-in
    I do walk to work every day. I ride my bike whenever I can also. I do live on the Oregon coast so the rain stops me. My husband is disabled so he drives the most. Those both are very good points. We need to all walk more and ride bikes if we can, best MPG you can get.
    I thought the tire guy told me it would be more harmful to the tires. He was just a young kid so not sure if he knew much. It was at a well known tire store. He did say enough to make me nervous. Said things like "Wear out tires sooner" "Void warranty" "cause a warning light to come on"
  7. rwhoyle
    rwhoyle Member
    227
    Tulsa, Oklahoma
    wantaprius,
    Air your tires up to 40/38 and don't worry about your tires. With your short trips, you will probably experience mileage around 40 to 42 MPG. You will not void your warranty or cause a warning light to come on by increasing your tire pressure. That's just lack of knowledge talk and plain bunk. You will actually increase your tire life instead of decreasing it as efusco states. Short trips and low tire pressure are big MPG killers. Pay attention to your MFD Energy display and it will teach you how to drive with varying throttle pressure to improve your gas mileage. Good luck and enjoy driving your new prii.!!!
  8. Celtic Blue
    Celtic Blue New Member
    2,224
    139
    Midwest
    There are a couple of things to consider:
    Negative
    1. The ride will be firmer and rough seams in pavement will give a thump.
    2. Traction in the wet is likely to be slightly reduced--and the low rolling resistance Integrities are already less grippy than many tires.
    3. Need to re-initialize your tire pressure warning system.
    4. Dealer/tire shops are more likely to fiddle with your tire pressures.
    Positive
    1. The car should handle better in cornering.
    2. The tires should last longer. The claims of "tires wearing out sooner" are the opposite of what owners are reporting and are non-sensical when you consider that rolling friction is reduced, not increased.
    3. There is more safety margin if tire is losing air, the warning system (if reinitialized) will activate at 75% of your set point (40 psig normal would warn at 30 psig if I understand correctly.)
    4. Increased fuel economy.
    5. Stiffer sidewalls should make the car squirm less.
    Considerations:
    1. When you increase your tire pressure, don't forget to reinitialize the TPWS. The instructions are in the manual and shouldn't be too difficult to follow.
    2. The claim that the tires will wear unevenly at increased pressure has not been observed by users of the Integrities. The assumption for the higher wear claim is that the center of the tread will bow out and result in uneven wear. In reality this doesn't happen at pressures below maximum sidewall and instead less edgewear is observed with higher inflation.
    3. The tires are still set below the max rating on the sidewall and should therefore still be within warranty. If you have a problem with your tires and are concerned they might hassle you about this, reduce the pressure in the tires before you take it into the shop.
  9. Tideland Prius
    16,159
    Most dealers or technicians will give you a hard time or just give you a warning. Heck, I even had them tell me that's it's too high when I asked to put the STOCK pressures of 35/33 lol. I usually tell them the factory settings then bump it up myself afterwards. That way, I can just point to the placard if they have any issues.
    Bumping up the tyre presures will give you a harsher ride, reduce rolling resistance (good for mpg, bad for grip... so keep that in mind) and will definitely change the characteristics of the wear pattern on the tyre. I've used 38/36 on mine in South Coast weather (probably the same as yours) and I didn't have any issue with heavy rains. I never tried 40/38 or 42/40 as the ride was harsh enough at 38/36.
  10. Celtic Blue
    2,224
    139
    Midwest
    In heavy rains I doubt there will be any issue with higher pressure and in fact it might be helpful in maintaining contact with the pavement. My concern is more with wet conditions in general rather than water covered roads. I do expect some reduced traction in the wet with higher pressure. (I would very much like to see this quantified.) Less body roll means more precise handling in my experience so there are tradeoffs.
    When considering rolling resistance my understanding is that there are two primary components: rolling friction of the tread contact patch and flexure of the sidewall. I do not know the relative distribution but recognize that higher inflation pressures will reduce sidewall flexure--this can actually be felt by the driver in the form of a firmer ride. Sidewall flexure is the major component of heat buildup in tires as I understand it and is what tends to result in tread/sidewall separation in underinflated tires.
  11. Tideland Prius
    16,159
    Well let's take the extreme case and you overinflate the tyres. The tyre will bulge and therefore only the centre of the tyre tread would be making contact rather than the entire width and thus there is a reduce contact with the surface.
  12. wantaprius
    66
    Oregon
    2014 Prius Plug-in
    Thanks for all the info.i feel much better about it. I will see how it goes on wet roads. That might be the only reason I see that might make me lower it. I don't feel the ride is rough at all.
    I was out on my bike today and I was thinking one kind of drives a Prius like you ride your bike. I try to make the best of the downhills so its not so hard going up!
    BTW what does TWPS stand for.
  13. richard schumacher
    7,663
    1,038
    United States
    TPWS = tire pressure warning system. Some Prius options will tell you when a tire's pressure changes a lot.
