Tire Pressure- what is the manufacturer recommendation?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by drw, Jun 21, 2007.
  1. drw
    drw Junior Member
    31
    I know that most everyone inflates the tires on their Prius to at least 40/38, but could someone tell me what is the recommended pressure by the manufacturer? I think the maximum is 44, but what is the stated recommendation- is it 35/35?
    Thanks
  2. lenjack
    lenjack Active Member
    804
    114
    Pennsylvania USA
    manual says 35/33
  3. aaf709
    3,862
    2022 Prius Prime
    There's a decal on the door post of the driver's side that says the recommended pressure too.
  4. Swanny1172
    Swanny1172 New Member
    666
    The tire makers don't normally recommend a pressure. That is the job of the auto maker. All the tire makers do is recommend that you stay under the maximum pressure which is listed on the sidewall of the tire.
  5. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    <div class='quotetop'>QUOTE(drw @ Jun 21 2007, 03:05 PM) [snapback]465971[/snapback]</div>
    Too low for best FE and tire life.
  6. richard schumacher
    7,664
    1,043
    United States
    The maximum pressure is right on the tire itself. The car maker recommends other lower pressures as a compromise between ride, handling, and fuel economy.
  7. gazz
    gazz Member
    216
    Coventry, UK
    drw
    Are you from Birmingham UK?
    The reason I ask is that I have 2007 with 16" rims but there is no maximum pressure on the tire wall.
  8. drw
    drw Junior Member
    31
    <div class='quotetop'>QUOTE(gazz @ Jun 26 2007, 08:39 AM) [snapback]468215[/snapback]</div>
    Nope, sorry, ALABAMA!
