Tire Pressure?
Discussion in 'Gen 3 Prius Main Forum' started by sLick415, Nov 7, 2012.
  1. sLick415
    sLick415 Member
    214
    55
    San Francisco, CA
    When adjusting tire pressure to max side wall (or any desired psi), is there a difference when tires are on the ground (supporting the car's weight) as opposed to when tires are off the ground?
  2. Xaran
    Xaran Junior Member
    95
    No, PSI is PSI, the tires may bulge more or not be flat on the bottom when on or off the ground but the PSI is the same unless you were to exceed the tires ability to expand than the force of the weight of the car could increase the PSI. The biggest difference you will encounter IMO is changes of temperature, I can have a 5-8 psi difference from cold 4am 42 degree pressure to mid day 75 degree and warm tires
  3. Mendel Leisk
    41,933
    Maybe someone doing their own tire swap over the next few days can check this out?
    I've thought about this (idly, never followed through and checked), when I've checked tire pressures before install. I'd suspect an unloaded, off the vehicle tire/rim would have slightly lower pressure. Might be negligible.
  4. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    The same amount of gas is in the tire. The only way the pressure is going to increase is to decrease the volume of the tire. I will bet the usual amount that sitting on the ground or sitting on a lift makes no difference.
  5. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Pressure will increase but you probably won't be able to measure the difference with an ordinary tire gauge.
    The reason it will increase is as load is increased the tire distorts and that reduces inside volume by a very small amount.
