Tire pressures
Discussion in 'Gen 3 Prius Main Forum' started by terry brecheen, Jul 21, 2013.
  1. terry brecheen
    139
    30
    houston, texas
    I've read differing opinions on here how much pressure one should put in the tires. I'm running 42 front & 40 rear. Is this too much or am I ok. Thanks for any help.
    49,508
    you're good to go. all the best!(y)
  3. attyjeff
    attyjeff Member
    153
    40
    same here 43 front 40 rear
  4. priusincc
    priusincc Member
    332
    16
    NV
    I'm running 38F and 36R. I was running higher, but now running closer to recommended pressure to see if it makes any difference in tire wear.
