Tire Problem
Discussion in 'Prius v Main Forum' started by dustmonkey, Jan 17, 2012.
  1. dustmonkey
    dustmonkey New Member
    23
    michigan
    I have a slow, persistent leak on D/S front tire. I called my dealer and they said take it to a tire place. I did and the guy said it's not a nail or other puncture but most likely a leak at the rim. Tire guy says take it to dealer.
    Q: Will Toyota cover this as the car is new and there has been no incident to cause the leak?
    sorry, car is a V5
  2. firepa63
    firepa63 Former Prius Owner
    1,761
    208
    If the rim is leaking, it's a warranty issue and the dealer should take care of it for you.
  3. fuzzy1
    10,170
    "most likely"? He didn't dunk it in a water tank to confirm?
    Even without a tub, I've confirmed bead seal leaks in newly mounted tires by laying the wheel flat on the ground at home and flooding the bead-rim joint with water.
  4. Mendel Leisk
    38,727
    +1 on "most likely". Try another tire place?
