Tire Question
Discussion in 'Gen 3 Prius Main Forum' started by Angry Elf, Dec 27, 2012.
  1. Angry Elf
    Angry Elf Junior Member
    35
    Yokohama Vs Michelin Energy Saver a/s . Does anyone have experience with these two tires ? I presently have the Yokohama tires that came on my Prius They have At least half their tread left at 20,000 mil . considering changing because I happen to have the extra money right now and I'm becoming obsessed with getting good gas mileage ... If I do change what can I expect the difference to be ? Thank you and realize Im new at this
  2. phoenixgreg
    phoenixgreg Senior member
    1,157
    289
    66
    Phoenix
    Welcome to PC :)! Some here have decided to replace their OEM tires with Michelan Primacy:
    Michelin Primacy MXV4
    These are superior for being quieter at highway speeds but they are expensive. They will be my next tires.
  3. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    They also drop your fuel economy quite a bit. :(
    A better choice for fuel economy would be the Energy Saver A/S. The Defender is another alternative if one doesn't need a ton of wet traction. They are more fuel efficient than the MXV4 and last a bit longer. For the price, the Continental PureContact and Bridgestone Turanza Serenity Plus are great tires but will cost you a bit in mpg compared to the Energy Saver A/S. The PureContact and Defender are probably pretty close in terms of mpg.
    Michelin Energy Saver A/S Review | PriusChat
    My MPG Results With Three Different Tires | PriusChat
    Initial Fuel Economy Loss With Michelin Primacy MXV4 Tires | PriusChat
    dmvp likes this.
  4. phoenixgreg
    1,157
    289
    66
    Phoenix
    Yep, it's true about the mpg loss (slight...maybe 3 to 4 mpg). It depends how often the OP is on the road and finds the cabin noise level to be irritating. I'd gladly sacrifice some mpgs for the noise reduction.
  5. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    With the Energy Saver A/S and Ecopia EP422 you don't have to sacrifice noise reduction for fuel economy. :)
    dmvp likes this.
  6. litesong
    litesong Active Member
    371
    122
    Everett, WA
    I buy used tires. Two weeks ago, I got a "used" but unused 70,000 mile, BF Goodrich Premier for $10 & a "used" but unused Goodyear Eagle GT for $30. Last week I got a "used" but never used Continental ProContact for $20. Yesterday, I put two 50,000 mile used Mastercraft tires ($29 for both) on my car. Today, I saw a Bridgestone Turanza Serenity for $40, mounted on a steel wheel, balanced & ready to put on a car.
    #6 litesong, Apr 23, 2019
  7. bisco
    49,434
    nice reawakening (y)
