Tire Recommendations for 2015 Prius Five 215/45R17
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by prevee5, Mar 20, 2025.
  1. prevee5
    prevee5 Member
    121
    Monrovia, California
    What is the tire of choice for a 2015 Prius Five?
    Best combo of efficiency, traction, low noise, wear
    In Southern CA so no snow, little rain
    215/45R17
  2. Hammersmith
    Hammersmith Senior Member
    2,315
    2,349
    North Dakota - USA
    2023 Prius
    Limited AWD-e
    You're posting in the gen5(2023-) section of the board. You're going to get a better answer to that question in either the gen3(2010-2015) section(if you have a 2015 Prius V - the top trim regular Prius) or the Prius v section(if you have a 2015 Prius v - the bigger Prius).
    Go back to the main page and scroll down to find the appropriate section.
    Grit likes this.
  3. Mendel Leisk
    41,557
    Except then he'll have duplicate threads. For expedience, I'll report it, one-and-only moderator will move it, all good.
    I went with Michelin Primacy MXM4. In the criteria you mention, efficiency is definitely taking a backseat, especially when new. A few years later it's coming back, I'm trying harder, getting complacent. Anyway, apart from that, it's been a very smooth, dependable tire for us.
    Oh, and it says "Green-X", apparently Michelin's Low Rolling Resistance badge, but shouldn't put too much weight on that.
    The tires that came on the car, new, were Michelin Pilot HX MXM4. They also had the Green-X badge, and I would say they earned it honestly. Not sure if they're still in production, the car's build-date was August 2009. One thing, they did crack pretty bad towards the end, but that was after at least 10 years in use, over 11 years from the tire's manufacture date.
    #3 Mendel Leisk, Mar 20, 2025
  4. Tideland Prius
    16,560
    *Moved to Gen 3 forum*
  5. Tombukt2
    Tombukt2 Senior Member
    13,065
    2,341
    Durham NC
    195 65 15 on stock or a 15 ya like 45 pretty stiff. Go cart
