Tire rotatation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by lorraine, Oct 14, 2009.
  1. lorraine
    lorraine New Member
    39
    monroe, ny
    How important is it to rotate the tires every 5,000 miles? I just bought my first Prius (2010 pk 111) a few months ago.
    Thanks,
    Lorraine
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    Just have them rotated with your oil changes. That'll be every 5,000 miles or if you want to go with the new unofficial as of yet change, every 10,000 miles.
    You may ask, what is this unofficial as of yet change of changing your oil every 10,000 miles? You can read about it here: http://priuschat.com/news/toyota-up...al-10000-miles-2010-prius-other-toyota-models
    Rotating your tires is important. Is it important enough to do at 5,000 miles? I feel it can wait for you to do your oil change, if that is 6,000 7,000 miles etc, just have it done at that time. But don't exceed 10,000 miles, that's just not good.
  3. floppyarms
    floppyarms New Member
    40
    Herts, UK
    Not sure if anyone came to a conclusion on other threads but as a rule of thumb should we move front to back and vice versa. Or Left to right? Or criss-cross them entirely?
    All the best
  4. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    I just move em' front to back, back to front.
  5. floppyarms
    40
    Herts, UK
  6. ceric
    ceric New Member
    1,114
    53
    Fremont, CA
    front/back or left/right?
    It depends on whether your tires are directional or not.
    If the alignment is good, front-back should be sufficient.
    Rotate tires as frequent as you can afford.
    I do it every two oil changes.
  7. paprius4030
    paprius4030 My first Prius
    2,077
    296
    York,Pa.
    Unless you do it yourself or go to a place that rotates them for free you'll pay as much as a new set of tires for all the rotations. I just leave mine alone until just before it snows and then make sure the best is on the front (ok insert groans here). Save your money for new tires.
  8. bps
    bps Active Member
    304
    119
    According to the manual, Toyota recommends rotating the tires straight back.
    Also, if you want to save money, just rotate your tires once at the 5,000 mile point, and then every 10,000 miles thereafter. (15,000, 25,000, 35,000, etc.) It's exactly the same as rotating them every 5,000 miles, but with fewer changes. If you do the math, you'll see what I mean. At no point and time will one set have more than 5,000 miles over the other...
    Bryan
  9. jburns
    jburns Senior Senior Member
    829
    111
    Archdale, NC
    Yep.:rockon:
