Tire Rotation
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Jonny Zero, Mar 25, 2013.
  1. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    What is the easiest way to rotate the tires on this car? Is there a safe jack point on the side to lift one side at a time? Or do you lift the front, put in jack stand, and the lift the back?
  2. retired4999
    2,652
    625
    Eau Claire, Wi.
    Check out owners manual pages 445-456
  3. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Your PIP must have a different manual. Mine only covered jack point for the front end, and rear end with a floor jack, and one wheel at a time with the supplied scissor jack. I am looking for a safe way to lift one side at a time so I can swap the front and back tires, without using the spare.
  4. retired4999
    2,652
    625
    Eau Claire, Wi.
    Mine shows the side jack points on page 453-456 ? If you look under the car you should be able to notice them behind the front tire and in front of the rear tire. :)
  5. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Yea but that lifts one corner at a time, I will need two jacks, or stick a jack stand there, in order to swap wheels. BTW I don't know how to fit a standard jack stand under the pinched sheet metal jack points on the side. :confused:
  6. retired4999
    2,652
    625
    Eau Claire, Wi.
    Yes! the side ones, take a look they will work with a floor jack also. just be carefull to get it under care enough to sit right.
  7. retired4999
    2,652
    625
    Eau Claire, Wi.
    I haven't looked but I think maybe some one like harbour freight maybe makes an adapter to fit on top of a floor jack to fit over the sheet metal. I think how ever there is room just on the other side of that sheet metal (toward the inside) so the floor jack just miss the sheet metal.
  8. retired4999
    2,652
    625
    Eau Claire, Wi.
    I had never looked under mine at the jack points. You are right not much room! I think a person needs to go to a store like, Harbour freight and check out some jacks with different resting plates and see if anything works? Sorry I just saw the jack points and just figured no problem! Some thing else to check out! My bad! :(
  9. NutzAboutBolts
    NutzAboutBolts Senior Member
    1,476
    1,552
    Bay Area
    There is no safe points from the side to lift up the vehicle. You'll have to jack the vehicle up from either the front or the rear. Here is the picture diagram to show you.
    frodoz737 likes this.
  10. Jonny Zero
    Jonny Zero Giggidy
    1,388
    351
    Austin, TX
    Hey thanks for your input anyway. I am very reluctant to put a standard floor jack or jack stand there, because of the small contact area. I actually dented the jack point a little, with the supplier scissor jack because of the rear end roll.
    Jacking up the rear | PriusChat
  11. Maroon
    Maroon Member
    159
    88
    Tupelo, MS
    I use a floor jack with the side jacking points, however I take a 18" long piece of 2x4 and place it along the rail so that the jack only contacts the 2x4 and doesn't mess up the little rail where the stock jack goes.
  12. Mendel Leisk
    38,721
    I half loosen all lug nuts, raise the front with the front/central jacking point, put in safety stands, repeat on the back. My aim is to get the whole car up with about 2" under the tires. I put the rear jack stands at the Owner's Manual proscribed points. The front jackstands I put inboard a little, at the front end of main underbody rail. When I've put the front jackstands at the rocker panel points it just seemed too much load on a very thin edge.
  13. Mendel Leisk
    38,721
    I can see your logic, but just raising the whole car at one go, per my post above, works quite well.
    I'd be reluctant to jack one side with a floor jack, even with a rubber pad type cradle. You're pretty much forced to put the jack somewhere near the middle of the rocker panel. And then it seems like you're trying to break the car's back, lifting all that weight at the center point.
    And having to repeat the exercise on the other side: doesn't seem more efficient.
  14. Tande
    Tande Active Member
    502
    302
    Mich.
    How about these...... Side Lift Pads
    retired4999 likes this.
  15. hlunde
    hlunde Member
    419
    74
    I use two jacks on one side and it works well.
  16. Mendel Leisk
    38,721
  17. hlunde
    hlunde Member
    419
    74
    I have two jacks modified to fit the Prius side jack points. I use both on same side to rotate tires --- front to rear same-side rotation. Black-colored block on smaller jack is solid PVC attached by recessed socket head machine screws.
    Valiant V and Mendel Leisk like this.
  18. GaryD1
    GaryD1 Active Member
    302
    138
    Seagrove, NC
    I purchased a couple side life pads, with the single notch in them, works the same as home made. The two jacks work very good. I just place the pad in lifting side rail notch where spare tire jack is to go and raised the jack up until contacts pad. I lift the rear jack a couple inches then go to front and do the same, then repeat until the two side tires are off the ground. You can use jack stands and emergency brake for added safety. As someone else stated, loosen all lug nuts prior the tire rotation works good. You are never under the car if it were to fall. I have tried lifting car front and rear, using stands, boards ect to get tires off ground. This is working for me being a two car prius owner, it make it faster and easier than any way I've tried so far. Thanks for all the tips on this thread!
  19. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    Yes, if you use the rocker panel lift points there is no way to insert a jack stand. You need two jacks that you can rely on (won't fall over or lower on their own). You should also use the rubber pads, available at most auto stores. Or you can use hockey pucks. ;)
    GaryD1 likes this.
  20. Mendel Leisk
    38,721
    I put regular cradle style jackstands on the proscribed rocker panel points once or twice, found them way too weak/unstable, then moved to points inward a bit, on relatively flat, heavy gauge material.
