Tire Rotation?
Discussion in 'Gen 4 Prius Care, Maintenance and Troubleshooting' started by Elt31987, Jun 10, 2016.
  1. Elt31987
    Elt31987 Active Member
    205
    149
    Derry, NH
    Has anyone else noticed that the Toyota procedure for rotating only goes front to back and never criss cross? Should this be the way i have them do it or should i cross them every other time?
    ETP likes this.
  2. booke02
    booke02 Active Member
    391
    415
    Israel
    Probably move between front and back on same side to maintain correct direction of rotation.
    ETP and Elt31987 like this.
  3. Elt31987
    205
    149
    Derry, NH
    ahhhh that must be it. Problem solved. Thanks
  4. Gen 2 Tom
    Gen 2 Tom Active Member
    333
    286
    Lincoln Park NJ
    Just my laziness here, not saying you should do this. But I never rotated the tires on my Gen2. 200K and I was getting about 75 K per set. When the fronts were done the rear didn't have much left. My driving was about 75% highway miles.
  5. ATHiker
    ATHiker Senior Member
    642
    560
    Massachusetts
    Four Touring
    The tire booklet that was provided with my owner's manual showed the criss-cross pattern, but further explained that you should defer to your car's owner's manual If it showed anything different. The owner's manual shows from to back, as has been noted.
    What's up with that?
    The recommended (and perhaps tire warrantee required) rotation interval of 5,000 miles seems especially ridiculous if just going back and forth on one side.
    I wonder how/why Toyota came up with 5k?
    bisco and Coast Cruiser like this.
  6. Coast Cruiser
    Coast Cruiser Senior Member
    2,267
    2,571
    Pacific Coast Highway
    As little as I drive now, I could go 5 years without rotating... Or, like Tom said, never rotate. I might just leave those OEM Toyo tires as is, and see how they do.
    Frederickdawg likes this.
  7. Mendel Leisk
    38,734
    Having snow tires in the mix, rotation just comes naturally. Toyota says keep them on the same side, so I go along with it. One benefit: only the curbside rims get chewed at all. Plus: the snow tires are directional.
    eric1234 likes this.
  8. Autoist
    Autoist Member
    119
    81
    Seattle Metro
    At my Firestone auto center your tire mileage waranty will not be honored unless you rotate every 5K miles. Isn't Bridgestone owned by Firestone? If so that would explain the rotation interval.
  9. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,801
    1,170
    Auburdale FL
    I never rotate them except off the car. Always get two at a time and put the new ones on the back. 42 is the Answer to The Ultimate Question of Life, the Universe, and Everything.
    Adequate tire inflation is the answer to great tire wear. At 42 for Prius and 51 for Honda I have never worn the center out or had catastrophic failure.
    But I have had cat failure.
  10. mark27lim
    mark27lim Active Member
    108
    103
    singapore
    I noticed this in the usa online manual and did a check with my physical manual which is in Japanese. the rotations for the Japanese manual are different. it is front to back and back to front but with a criss cross only for the back to front tires. that way every tire gets to move to all four corners each cycle. I'd take a photo if anyone needs it.
    bisco, Spindifferent and Mendel Leisk like this.
  11. Spindifferent
    Spindifferent Member
    155
    79
    Central Texas
    Please do post a photo.
    Thanks.
  12. bisco
    49,504
    i didn't rotate my oem's for 42,000 miles. now, i'm getting a flat spot or something noisy in one of the rears. they still have good tread, and very even wear. i tried cross rotating them, and that made the noise 10 times worse. i may just buy another goodyear for the bad one, or maybe two new michelins.
  13. mark27lim
    108
    103
    singapore
    as requested. I presume thats because jdm stock tires are bidirectional? pls check usa stock tyres first if you intend to follow this rotation pattern. I also noticed usa manual engine oil specs for 0w20 only but jdm spec seems to allow for 10w30..
    ETP and Mendel Leisk like this.
  14. ETP
    2,801
    1,170
    Auburdale FL
    I am a unidirectional type person:LOL::ROFLMAO:
    booke02 likes this.
  15. ETP
    2,801
    1,170
    Auburdale FL
    Related question. Does anyone have experience with this brand of tire? Looking to get 4 for my son's Caravan,
  16. alanclarkeau
    alanclarkeau Senior Member
    7,044
    7,584
    near Brisbane, Australia
    Australian manual shows the same (only with English Text except for the spelling of TYRES is TIRES). But it also has an option of "VEHICLES WITH FULL SIZE SPARE TIRE" - which I'm told isn't available. From what I see, my Bridgestones aren't unidirectional.
    I had a friend in the tyre sale business, he said he NEVER rotated his own tyres - would do customers if they requested. His philosphy is 1) you put your best tyres on the back because most spin-offs are when the back end loses traction - I quizzed Dunlop headquarters about that, and they confirmed it in writing; 2) should there be an alignment or mechanical problem, you may not pick it up in a 7500km rotation, and end up ruining 4 tyres instead of just 2. 3) he let the fronts wear out (faster than back, particularly in FWD) - move the backs to the front, same side, so they rotate the same direction and put new tyres on the back. (He was also adamant that steel belted radials should run in the same direction for their entire life unless you're going to rotate them ridiculously regularly.) I've been doing that for nearly 40 years now. My car, at service has a note sitting on the dashboard "Please don't rotate my tyres".
    ETP likes this.
  17. ETP
    2,801
    1,170
    Auburdale FL
    Perfect.
  18. eric1234
    eric1234 Active Member
    390
    198
    Hamden, CT
    This is starting to take on the characteristics of one of the extended warranty threads.
    Do what you like. The fact remains that the automaker employs (and/or engages via their vendors) engineers highly specialized within certain fields. The sum experience of these highly specialized engineers is summarized in the automaker's recommendations.
    If someone decides to do something different (and may have done so for "years") that's fine - but unless you're a tire/suspension engineer, it's highly unlikely that what you're doing is better than the recommendations that are provided from the manufacturer.
    Just speaking as an engineer that has been part of various industries, and witnessed first-hand the effort that goes into providing manufacturer's recommendations...
    ETP, krmcg and booke02 like this.
  19. ATHiker
    642
    560
    Massachusetts
    Four Touring
    Yea, but....
    The brochure that came from my tires' manufacturer recommends a rotating protocol that sees each tire moved to all 4 possible positions, "unless the automobile manufacture suggests differently".
    As such, one cannot help but pondered if Toyota is recommending a sub- optimal "front-to-back only" protocol simply because it does not trust the person changing the tires to check and follow the specific recommendations for the tire.
    In other words, to make the decision on how to rotate idiot proof.
    On a related note, I think that a 5,000 mile rotation interval make more sense if I tire is going to be mounted in 4 positions, rather than just two positions. I also think that when recommending the rotating interval, the tire manufacture may feel it best to suggest just one interval regardless, to keep it "simple".
    Or to put this a different way, I have concluded that it is a waste of my time to have my tires rotated front to back every 5,000 miles. And the risk of dinging to the black powder coat (already done on my first change) or damage caused by another opportunity to over torque or under torque, out weighs any benefits.
    If I drove fewer miles a year, I might think differently as I would want to have the wheel taken off anyway to check/service the brakes (I had sticky/frozen caliper issues on our 2010 more than once).
    alanclarkeau and ETP like this.
  20. ETP
    2,801
    1,170
    Auburdale FL
    Never tried that on any car but has anyone else done that and can report the results?
