Tire shop recommends replacing front struts
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by meter, Jul 17, 2023.
Tags:
  1. meter
    meter New Member
    Santa Rosa
    Please forgive me, as I'm not very knowledgeable about car maintenance, although I'm trying to learn as much as I can (the most I've done is replace the spark plugs on my Gen 3, which was actually pretty rewarding).
    I got new tires today, and now, they're recommending that I replace my front struts within 2-3 weeks. Apparently, they're "bottoming out." The quote is $800 to replace the front struts, plus another $800 to replace the rear shocks (they didn't mention the rear shocks when we talked, and I didn't notice until I read the quote more closely).
    A few questions.
    1. I have no clue how to interpret the attached pictures (and unfortunately, I didn't get an explanation from them). Is there something specific I should be looking for?
    2. I haven't really noticed my car bottoming out when I drive, but maybe I'm just missing it. Are there any obvious signs?
    3. How urgent is this? And do I really need to replace the rear shocks as well, or can I wait on those?
    4. Is it worth trying replace the front struts myself to save money, assuming I buy the full assembly online? I have access to a car jack and tools. Of course, if it involves compressing shocks myself, I would never attempt it.
    Thanks
  2. Tombukt2
    Tombukt2 Senior Member
    13,056
    2,339
    Durham NC
    Yes swapping complete units is quite easy. They're are tutorials on you tube . The Prius is pretty much based on the Corolla very similar front struts and very similar rear You buy whole assemblies on like eBay or wherever it'd be nice to get KYB gas adjust complete units or maybe something from tokikco. You would be pushing it to have 350 bucks in parts and that's top of the line quite unnecessary actually but I'm just quoting the good stuff.
  3. JC91006
    16,774
    8,569
    You don't have to pay attention to those sales guys, what they are trying to do is sell you additional services, besides the tires you already purchased. Unless there are specific reasons why you need the struts and shocks, I would just ignore their sales tactics. If you're not noticing it bottoming out, it probably isn't
    JohnPrius3005 and Mendel Leisk like this.
  4. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,468
    2,435
    Taylors, SC
    I'd watch The Car Care Nut's video before doing anything.
  5. ASRDogman
    ASRDogman Senior Member
    7,613
    3,920
    How many miles do you have on the car?
    Does it feel solid while driving? When you go over bumps, does it feel smooth or
    does it feel hard?
    Watch a few video's and purchase a few good tools. You can buy complete strut assemblies
    from autozone and install them yourself...
    Same with the rear shocks.
  6. meter
    meter New Member
    Santa Rosa
    Thanks everyone! Really appreciate the advice.
    After watching through some videos, I’m pretty confident I can DIY this (with the help of a friend).
    does it feel hard?
    154k miles.
    The ride feels a bit bouncy when I go over a speed bump, for example. But nothing too extreme. I’ll pay attention more closely this week as I drive.
  7. anonymous
    anonymous Member
    177
    99
    US
    if you're satisfied with how it drives you don't reaally have to. the shock absorbers gradually get weaker so the ride gets rougher and bouncier but they still work way better than nothing to keep the springs from bouncing out of control. I just replaced all struts and shocks after 12 years from the model year and like 6 years after a shop said to get new struts (yea the bellows were all broken just like that), at 290k miles cause I started noticing issues with handling and oil on rear struts. and there is a significant improvement, smoother ride and bumps get smushed over like they're supposed to, no rebounding past the resting point.
    you can buy the whole front strut with spring (quick strut) or you can rent a macpherson spring compressor from autozone for free; I think with that proper tool it is safe and easy to do, it has safety pins so the spring can't pop out of the hooks. just put one on either side and tighten by wrench alternating each side. you will also either want a replacement "coil spring insulator" which is integrated with the bellow, or you can use the replacement bellow that integrates with the bump stop, in combination with the remenants of the rubber coil spring insulator.
    the question is what strut to get. you could get the nice cheap generic kits from ebay or autoshack but they could be junk who knows. monroe looks like a good value and is made in usa but from what i hear on the web monroe sucks and kyb is the best. kyb is the OEM and the most expensive. but I decided on that cause I didn't want to compromise if it has a direct immediate affect on ride quality.
    rear struts are super easy to change once u get the interior out to access the top. u will need a hex key and "box" wrench to do the top nuts.
  8. ASRDogman
    7,613
    3,920
    You need to replace the bearing also.
    And by the time you add the cost up, it's more than getting an assembles strut.
    It is a lot easier, faster, safer, and cleaner!
    Plus, you have to do all the hard work!!!!
    No sense in going cheap with struts and wheel bearings. Unless you just like replacing them
    every 3-4000 miles..
  9. Fifen
    Fifen Member
    77
    33
    Utah
    I just did my struts. I couldn't afford kyb struts so I got TRQ. I figure 97% of the driving is on paved roads. And they have a lifetime warranty. I can update after a while if I notice anything
    SM-N986U ?
  10. ASRDogman
    7,613
    3,920
    Oh no! trq is crap! Decades ago they were good, no longer.
    I hope they last longer than their hubs, about 3000 miles...
  11. Fifen
    Fifen Member
    77
    33
    Utah
    I guess I'll report back in 3000 miles. Haha
    SM-N986U ?
    ASRDogman likes this.
  12. ASRDogman
    7,613
    3,920
    I do hope they last longer for you. But after the experiences with the hubs,
    front and rear, I'd never buy that brand again.
