Tire Sidewall blown after psi raised to 34
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by gboss, Apr 4, 2022.
  1. gboss
    gboss Member
    82
    31
    Bay Area
    What do you guys think - should I replace it asap or do I have any milage left? I did some reading on the forums and decided to raise the psi on all of my 17" tires to 34 psi. About a week later, I came out this morning and found:
    I really wasn't planning on replacing the tires as I bought this six months ago from the dealer and have a fair amount of tread left. After buying the car, I drove across country and stopped at a Costco tire center along the way to top up on air and one of the techs said that he thought this tire looked like it had a damaged sidewall.
    I wonder if overloading the tire's pressure beyond factory spec made minor damage to the sidewall more severe.
  2. JC91006
    16,479
    8,397
    Your life = priceless
    A couple new tires = $300
    mypriuscious and Montgomery like this.
  3. 2010moneypit?
    2010moneypit? Active Member
    314
    122
    Beaumont ca
    Looks like side wall damage. Replace it.
    Montgomery likes this.
  4. gboss
    gboss Member
    82
    31
    Bay Area
    Any recommendations for 215/45R17? I was looking at Ecopia or MXM4, but I don't need a tire that lasts 100k miles. Just looking for decent mpg and performance for a couple years without spending $180/tire.
    douglasjre likes this.
  5. prius16
    prius16 Active Member
    462
    243
    New England
    2022 Prius Prime
    That tire has obvious sidewall damage. That caused the split.
    That tire needs to be replaced asap!
    Do not go over 30mph. Even then, it's hard to say how long that tire will last.
    34 psi is nothing to a good tire.
    On the tire, it will last the max tire pressure.
    It also looks like an older and/or sun damaged tire.
    Also, from your location, that car may have previously spent time near the shore. Salt from the sea can do very nasty things to cars.
  6. prius16
    462
    243
    New England
    2022 Prius Prime
    Imho, for a 215/45R17, the best for the money:
    Pirelli P7 AS Plus 3
    P7 AS Plus 3 - Size: 215/45R17
    $146
    Firestone Firehawk AS
    Firehawk AS - Size: 215/45R17
    Price $141
    Michelin Primacy MXM4 | P215/45R17
    Primacy MXM4 - Size: P215/45R17
    Price: $175
    Imho, I think that the Michelin MXM4 is much better than either the Pirelli or the Firestone tire above.
    Imho, from TireRack's selection, the Pirelli P7 AS Plus 3 is cheapest all season tire that I'd use.
    Imho, be careful of the BS UTQG ratings. Many are like dress sizes - are mostly made up.
    Fwiw, imho, the Pirelli's I've used in the past lasted longer than better rated tires. Because availability, I got 2 Pirelli tires and 2 other similar tires (same size, same category, even similar tread design). However, Pirelli has limited tire models and sizes. So, they are no longer an option for that car, and the desired type of tires.
    Good Luck!
    #6 prius16, Apr 4, 2022
  7. prius16
    462
    243
    New England
    2022 Prius Prime
    Note, the tires I mentioned above are all season.
    The tire that blew is a mud+snow (M+S) tire.
    I picked all season tires above, because of the location you listed.
    If you need an M+S tire, make sure that the tire/model is M+S rated.
    Good Luck.
  8. gboss
    gboss Member
    82
    31
    Bay Area
    These are the tires that came with the car when I bought them (in another state) - they are Falken Ziex ZE950 (M+S). I was going to replace just the front two tires, but I wonder if having (M+S) on the rear with new all season tires on the front will cause issues.
    Thanks for the recs - the Pirelli sounds good and TireRack has them. My local Costco is also running a $150 off Ecopia EP422s if I buy 4 or they carry the Firestone Firehawks at $145 a piece.
    #8 gboss, Apr 4, 2022
  9. prius16
    462
    243
    New England
    2022 Prius Prime
    Unless your other two tires are bald/bad, the other two tires should be fine.
    From what I could see, the tire you showed did look very worn, and near the end of it's useful/legal tread depth.
    Imho, if you can, then I'd recommend that you 4 new tires now.
    If money is tight now, then get the other two tires within 6 months.
    They sell tread depth gauges for ?~$8?.
    To get a rough idea of tire wear, google
    tire tread depth chart penny
    Fwiw, since you have ABS and traction control, many tire stores will Tell/Require you to get all 4 tires at once.
    Fwiw, in some States, it's the law.
    For some companies, it's to protect them against any possible law suits.
    So, if you want only two tires replaced, the tires may need to be carried in.
    You may need to tell them the tires are for an off-road only vehicle.
    Tire-rack will do the same thing for mounted tires on wheels.
    As of a few years ago, besides a separate email confirmation, I _had_ to also do a phone voice verification that the Two tires and wheels were for an off-road, never on public road, vehicle.
    If you don't drive in snow, get All Season tires.
    They'll last longer, have better handling, and performance.
    For an M+S tire, the tread has to be softer to prevent the tread from being to hard in the snow, and at temps below ~30F.
    Fwiw, there are extreme performance summer tires.
    In temps below 50F, they loose a lot of traction.
    In temps below 40F, because of the lack of traction, they are unsafe on the highway(from the tread being hard, with little grip, at those cold temperatures).
    I know all too well. :eek:
    Good Luck!
    gboss likes this.
  10. jerrymildred
    jerrymildred Senior Member
    11,508
    14,110
    Tampa, FL
    See that indentation?
    You hit debris or a pothole. Looks like you may have bent the wheel besides rupturing the sidewall. Judging by the cracks in the rubber, it happened a while back. The belts broke at that time and there was a bulge in the tire that finally let go.
    Even without damage to the rim, that tire is not repairable. Holes in the sidewall are the end of the road for any tire.
    I don't know what tire pressure you were running before, but even 34 psi is a little lower than the recommended pressure. But it looks like it was pretty low since the tread is almost gone at the edge of the tire. Most Prius drivers here use about 40 psi. I keep mine at 42 front and 40 rear. The tread wears very evenly.
    tony_2018, MrPete, Montgomery and 2 others like this.
  11. Mendel Leisk
    38,700
    You’re joking, right??
  12. Salamander_King
    Salamander_King Senior Member
    10,973
    8,856
    New England
    That was exactly my thought. I can't believe it is still holding air in that condition.
    Montgomery and Mendel Leisk like this.
  13. ChapmanF
    15,557
    Depending on the tire dealer, there may also be the option to buy two new tires and have them shaved to match the circumference of the best two older ones they'll be shared with.
    That doesn't make a lot of sense unless the older ones are still fairly new.
  14. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,788
    2017 Prius c
    NO. It made some BAD damage show up in a more obvious fashion.
    Your question about having more mileage left is just a joke......right ???
    In addition to the damage, it looks like those tires are OLD too.
    Replace them all.
  15. sam spade 2
    7,035
    2,788
    2017 Prius c
    I don't think so.
    What States exactly ?
    Specifics, please.
  16. gboss
    gboss Member
    82
    31
    Bay Area
    ...I am very serious ;)
  17. gboss
    gboss Member
    82
    31
    Bay Area
    Good eye. It would make sense - I've been slowly uncovering minor secrets that the honest and straightforward Toyota dealership hid from me including a front bumper that had been cracked/filled/painted (probably just from hitting a wheel stop in a parking lot...but still.).
    I just bought 2 Yokohama Ascend GTs online to replace the front tires, so we'll see how they hold up compared to these Walmart Falken wheels. I'll try the 42/40 psi setup as well.
    jerrymildred likes this.
  18. prius16
    462
    243
    New England
    2022 Prius Prime
    I also wanted to add, that unless the person is in a heavy snow area, many/most All-Season tires are fine for non-heavy winter/snow.
    In New England, in general, that would roughly mean All-Season tires, that are in good shape, are generally okay in most areas that are South of the Southern tip of Maine.
    Of course, for major snow storms, or for ice, for safety, real snow tires are needed.
    The Michelin mxm4 tireS are M+S rated.
    Buy Michelin Primacy MXM4 Tires | Michelin
    Fwiw, what M+S and the three mountain peak symbols mean on tires, in regards to snow performance:
    Mountain/Snowflake Symbol Tires & M+S Tires Explained - The Tires-Easy Blog
    I know so!
    Use google. I'm not your flunky.
    Have you ever heard of Google?
    Or done anything yourself, other than make false/incorrect comments?
    You also clearly don't have any idea how ABS, traction control, stability control, 4wd, nor AWD work.
    You don't have any idea of my background, nor experience.
    RTFM. :)
    From the Prius 2020 manual.
    (Took all of a few seconds to find. If interested, even a pre-schooler should've been able to find the info within a very short time.)
    gboss likes this.
  19. prius16
    462
    243
    New England
    2022 Prius Prime
    Fwiw, I try to reply to messages based on the expected/likely members.
    Many 16/17 years olds drive Prius cars. So do many college students.
    Not everyone is interested in learning about cars. Many people have other interests other than cars.
    At the same time, I can be brutal on forums for older sports cars. I can eviscerate a person in seconds. :) No time for trolls.
    If someone is working on a multi-decade old sports car, they better be ready, and used to, looking at repair manuals.
    I taught engineering for many years.
    I quickly learned that if one person has a question, then many people likely have that same question.
    Everyone has a different background, different knowledge, and different experiences.
    At the same time, if some idiot asked me what I meant by "we differentiate this", I'd point blank ask them how they got that far in engineering, without basic calculus.
    Be considerate, but don't be a push-over! :)
    #19 prius16, Apr 4, 2022
  20. ChapmanF
    15,557
    Funny, you've just done the same thing Sam typically does when asked about support for something he has claimed.
    Don't let someone slap you on the back at the same time, or you could get stuck that way.
    Mr. F and jerrymildred like this.
