Tire size question and effects on MPG
Discussion in 'Gen 3 Prius Accessories and Modifications' started by johnnyn1322, Mar 30, 2010.
  1. johnnyn1322
    johnnyn1322 New Member
    Westminster
    So i have a 2010 prius III model
    my question is how much will 16 or 17 inch rims affect my normal MPG?
    does anyone know what the 38mm 40mm etc etc..is? and what it effects?
    i enjoy being able to make a full uturn on a small street...
    205/55R-16 38gmp <---whatever that is
    will these fit ok?
    but as soon as i get free time i'll go to a tire place and ask..but wanted to get some input
  2. Nuckz23
    Nuckz23 Member
    127
    Santa Clara, California
    There are a few factors to consider for mpg loss: weight of wheel and tire, aerodynamics of wheel, and the rolling resistance of the tire you choose. The 38 and 40 mm you are refering to is the offset of the wheel. Do a google search on offsets to learn more. You can even go to tire rack and read up more about wheels in general.
  3. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    I posted a response to a similar question in this thread:
    http://priuschat.com/forums/gen-iii...ions/78557-will-wider-tires-decrease-mpg.html
  4. pakitt
    pakitt Senior Member
    2,173
    1,311
    Colorado
    According to declared fuel consumption numbers here in Europe based on EU driving standard cycle, the difference is 0.1L/100km (or about 1 MPG) more with 17" wrt 15" on all test cycles (city/suburban/combined). There is no reason why it should more than this, since test conditions are the same and the wheels are the only thing that change.
  5. 32kcolors
    32kcolors Senior Member
    5,683
    952
    124
    Redondo Beach, CA
    There are posters who've taken a bigger mpg hit than that with aftermarket wheels, even with lighter rims but which are less aerodynamic compared to stock 17".
