Tire sizes, +16, +17, how to make up on spedometer?
Discussion in 'Gen 2 Prius Main Forum' started by hunterxaz, Jun 20, 2011.
  1. hunterxaz
    hunterxaz New Member
    28
    Salt Lake City, UT
    So some of the links on this site like here, Tire size calculator shows a change of 24% switching from a 15 tire to 17", that's huge. How can you offset that?
  2. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    you change to a lower aspect ratio to keep the overall diameter close to the original.
    for 17 inch you use a 205 45 tire
    for 16 inch you use a 205 50 tire
  3. F8L
    19,011
    4,080
    50
    Grass Valley, CA.
    For a 17x7 or 17x8 wheel I would suggest a 215/45/17 or a 205/50/17. These sizes will keep you close to you OEM tire diameter. More importantly, the size tires I suggested will help correct the 2mph error (too fast) the speedometer exhibits. The 205/45/17 is really close to OEM size and will definitely work but it is a bit smaller than oem size so the speedometer error gets worse. Your call. :)
