tire spinning or battery spitting?
Discussion in 'Gen 2 Prius Main Forum' started by feethanddooth, Mar 13, 2005.
  1. feethanddooth
    feethanddooth New Member
    31
    new jersey
    have had this problem a few times.
    when i need the car to perform it feels like the either the tires are spinning and not catching or the the engine is not responding. is this because of the batteries? anyone else have this problem? advice?
    thanks. :)
  2. Sufferin' Prius Envy
    Sufferin' Prius Envy Platinum Member
    3,998
    To me it sounds like the car IS performing . . . traction control.
  3. xevious
    xevious New Member
    187
    Oregon
    Perhaps you could be a bit more specific. Are you talking about highway performance or starting-line acceleration? Please describe the circumstances and symptoms in more detail, and you'll have a gaggle of folks giving you performance advice.
  4. feethanddooth
    31
    new jersey
    its from start line. if i need to merge into traffic and really need the car to go! the car sputters. almost feels like the tires are slipping but not. just cant tell if it is that or maybe the batteries/engine cant put out that kind of power.
  5. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Almost certainly the traction control. Power is dramatically cut to the wheels if they sense even the slightest amount of loss of grip. If you want to accelerate quickly you need to gradually apply power over a second or two, once moving you can lay the power to it without a problem.
  6. Dr.Jay
    Dr.Jay New Member
    55
    South Jersey
    Did you have the front wheels turned when you noticed this?
    I'm a new Prius owner and I get this a lot. Seems like it can't make up its mind whether to use the battery or ICE for a split second. But I don't notice it when I'm pulling straight ahead.
    Scares the H**L out of you. Feels like the cars stalling. ;-)
  7. richard schumacher
    7,663
    1,038
    United States
    And if the engine is not running at that moment (and if it's already warmed up, it probably isn't) then there is a slight lag while the engine is started and begins to provide significant power. Try less-than-flooring it for the first half-second and see whether that helps the feel.
  8. cowboyonthemoon
    cowboyonthemoon New Member
    Kutztown, PA
    I had noticed this too but wasn't sure what to think. For a while I was convinced that this meant a trip to the shop. But like most things in life, you learn to adjust to it and all is good. I naturally evolved my driving technique and now do the moderate acceleration with plenty of zip. This car continues to amaze me by showing me how to DRIVE BETTER.
  9. xevious
    xevious New Member
    187
    Oregon
    Root cause is the factory tires aren't very "grabby." When you floor the accelerator from a stop, the Prius generates more than enough torque to exceed the tires' ability to hold static friction, which results in a spin-out.
    In a "normal" vehicle, this would result in much squealing of tires and leaving of tread.
    In the Prius, however, the traction control (not to be confused with vehicle stability control) kicks in to prevent the transmission (PSD) from being destroyed by overreving, and the power to the wheels is interrupted or greatly reduced for about a second, causing the vehicle to feel as if it has stalled.
    In heavy traffic, this is dangerously annoying, especially when the traction control stalls your acceleration while attempting to pull out in front of an oncoming Hummer.
    The solution is either to upgrade your tires, or to adjust your driving style: When starting off the line, accelerate slowly for the first 5MPH or so, then feel free to floor it. Be cautious when your tires are on wet, slick, or painted (e.g. a crosswalk) surfaces, as these will encourage tire slippage.
    Given proper tires and surface, this car can really zip off of the starting line. No engine can develop the kind of starting torque that is delivered by an electric motor!
  10. chasabel
    chasabel Junior Member
    39
    Shady Grove, PA
    My daughter-in-law had something like this happen to her recently.
    She was in the middle lane of an interstate in MD driving in light
    snow, when she said the car just started slowing down even tho
    she was pushing on the gas.
    She was able to get over to the side of the highway and stop.
    She called my son on the cell phone and he told her to try to go again.
    She did and every thing was fine the rest of the way home.
    By the way they got her car the last week in Dec. 2004 and she already
    has over 10,000 miles on it (74 miles one way to work).
    She is quite happy with it. They traded in her 2003 Ford Escape for it.
    She was stopping for gas 2 times a week before. I forgot to ask her
    how often she stops now.
    Charlie
  11. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    That sounds like a different problem that may need attention, though it should have lit the big bad triangle if it was what I am thinking. There is a re-calibration programming for that.
    If traction control is activated, you should see a yellow car with squiggles (slippery surface) symbol briefly blinking. Sometimes though TC is so brief, the icon doesn't light.
  12. xevious
    xevious New Member
    187
    Oregon
    As far as I know, the vehicle slip indicator (car with squiggles) only comes on if VSC (vehicle stability control) - not the traction control - is activated. Or do they both trigger the slip indicator?
    VSC is inactive at speeds below 9MPH.
    I agree that this is a completely different problem. If the VSC wasn't beeping like crazy while your daughter's car lost power, I'd say it's time to visit the nearest service center.
  13. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    Generally (to me anyway), when you are at a light long enough for the gas motor to shut down, and then step on it, there is a lag before things get going. AS someone mentioned, if the motor is cold, it is worse.
    If the tires were really spining you couldn't miss the indicator.
  14. efusco
    19,891
    1,192
    Nixa, MO
    Ok guys (and gals), I think this thread is starting to create confusion.
    1)Chasabel's situation is very different than the one in the original post and sounds as if the car went into 'limp home' mode. Should be checked out at the dealer to pull codes for possible fix.
    2)VSC activates the light on the dash (car with wiggly lines) AND the in vehicle chimes.
    3)TRAC (traction control) activates no chimes, as Danman mentioned it usually lights the dash, but not always--the same indicator as VSC...again, but without the chiming of VSC.
    Finally, I stand by my original assessment....this sounds like a simple over aggressive acceleration attempt for the conditions (ie wet or gravelly road) or the tires. The computer senses slip way before you will hear or feel it and it immediately cuts power to the wheels.
    I often notice a sort of surging under the TRAC engage situations...tires catch, slip, TRAC engages, repeat, until I get moving.
    Now, the possibility of the momentary delay in the ICE catching was mentioned. That is possible. But, there is a very different feel with that than with the TRAC.
    With TRAC there's the initial movement, then sudden loss of movement...your body leans forward as if the brakes had been tapped.
    With the ICE delay there's a movement forward that is a little slower than expected then the ICE catches and pushes you back into your seat.
    Can I clarify this any more for anyone?
  15. jayman
    jayman Senior Member
    13,439
    640
    Winnipeg Manitoba
    Evan:
    Nope, you did good son.
    I think the Trac is too aggressive, but it has to be to prevent the enormous electric torque from destroying the PSD.
    I knew the Trac was too sensitive when we had our unusual sleet and freezing rain here, back in November. I tried driving up an icy parking ramp to an upper deck and the car just *stopped* on me.
    Right to the mat, the VSC icon illuminated, and the car stationary. Fortunately, nobody was behind and I was able to back down. Oh, I did some experiments in an empty and icy truck parking lot, the Trac also works in reverse.
    I solved most of this annoying problem by putting on Dunlop Graspic DS-2 winter tires. With those tires, on snow and ice the Prius will happily blow away other cars and 4WD's with all season tires on them.
    The aggressive Trac is something you learn to live with. There is no disable button.
  16. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    Trac isn't too agressive.. tires just suck. Electric motors have 295 ftlbs of torque at 0mph... that's the same torque my High Output 5.0L V8 had at around 45000 rpms... with other tires, it no longer does this.. unless you really really punch it and turn.. but that's a given. there is a difference between acceleration out of parking lots and attempting do donuts.
  17. popsrcr
    popsrcr New Member
    232
    Richmond, VA
    Yeah, I was referring to the original post. I have never had traction control come on in the car, so I wouldn't know what it felt like. I just feel that hesitation waiting for the gas motor to kick in when leaving the light.
  18. xevious
    xevious New Member
    187
    Oregon
    Depends on where you live... ever taken a drive through lovely Boston? ;)
