Tire warning light
Discussion in 'Gen 3 Prius Technical Discussion' started by socal13, Dec 5, 2023.
  1. socal13
    socal13 livin in the foothills...
    262
    86
    Altadena CA
    Hello! The tire symbol lit up on my dashboard (gen three 2013, 61k miles, 20k miles on Michelin tires) while I was on the freeway so I pulled off thinking I had a flat tire. I checked all tires and they were properly inflated. Brake fluid was ok too. The day before I had one tire at 27 lbs so I may have a slow leak. I inflated it to match the other tires at 36 lbs but no warning light at that time. But the warning light continues to be lit.
    Any thoughts and how can I reset the light? Thanks, Doug.
    #1 socal13, Dec 5, 2023
  2. ASRDogman
    ASRDogman Senior Member
    6,054
    3,251
    Seeing that it is 10 years old, I would guess the battery in one of the sensors is dieing...
    Might as well get 4, because the others will start to go before too long.
    I had one going out, now there are two. I have 4 new ones, just too lazy to replace them. :whistle:
    socal13 likes this.
  3. JC91006
    16,474
    8,393
    buy 4 new sensors on Amazon for about $42.00 roadfar brand
    socal13 likes this.
  4. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    So only $10.50 apiece? How confident can we be that ones that cheap are fully functional and reliable?
    My tire pressure light came on for the first time a couple of weeks ago. That was not surprising, considering that their batteries are nearly 13 years old. I might just ignore the light, unless legit replacements can be had for not much over $42, installed when I next need new tires.
  5. JC91006
    16,474
    8,393
    I've purchased numerous sets of these sensors and they work perfectly. No issues at all
  6. Mendel Leisk
    38,644
    Our ‘10 (built Aug 09) had the light come on, stay on a day or two, then inexplicably went out. This was about 6 months back.
    My position: when ours do fail I’ll be doing nothing, just carry on, and get regular valves when it’s time for new tires.
    But for OP, if he wants to maintain TPMS, I’d at least give it a while; they may come back on.
  7. CR94
    CR94 Senior Member
    2,642
    1,137
    Northwestern S.C.
    It's interesting that yours outlasted mine in terms of time---although not distance travelled. I can't imagine why the light would go off unless it had been on due to actual low pressure--which could be partially temperature-related..
  8. bdc101
    bdc101 Member
    250
    88
    usa
    If you had a cold night and the tire pressure dropped, and then you didn't drive it again until until a warm afternoon, the light might go out on its own.
  9. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    On my old 2006, I had one go bad at 9.5 years and the others lasted closer to 12 or so years. During that period I fudged one reading with a binder clip to keep the light off, just for fun. At some point I replaced them all. I had been fiddling with one OEM TPMS in my hands I got extra due a flat, with Techstream, and I started to realize pressing on the TPMS showed "fake" pressure ( I was trying to see the temperature increase but surprised pressure went up too).
    #9 wjtracy, Dec 13, 2023
