Tire wear - how many miles are people getting on their stock tires?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by rrolff, Mar 28, 2011.
  1. rrolff
    rrolff Prius Surgeon
    1,610
    246
    So Cal
    Haven't seen a post on this - would like to hear from others on how many miles (and Brand/15" or 17") they had before the tires were finished (and did you rotate).
    I've rotated every 5K up to 25K - the last 10K no rotation. On my oil change (35K), I noticed all the tires have even wear - but they have evenly worn out (thought I'd get more than 35K).
    BFgood 15" tires. 35K miles - 44 PSI - worn to tire wear bar (horizontal lines).......
  2. Mark57
    2,945
    2,737
    OK
    I just past 30,000 on my stock 15" Yokohama Avid's. Rotation is every 10,000. Wear is even and they look to have at least another 10,000 left. I don't wear them down too close before replacing. PSI = 42/41.
  3. Michgal007
    Michgal007 Senior Member
    1,321
    98
    Macon, GA
    I am wondering about the same thing...
    I have 55,000 miles on original tires. Rotated every 5000 miles (more or less). I am wondering if I should get new ones...
  4. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    Check the tire tread in relation to the wear bars. If the tread is flush with the wear bars, time for new tires.
  5. jdcollins5
    jdcollins5 Senior Member
    5,131
    1,338
    Wilmington, NC
    I have the Yokohama Avid's, 15" standard, with 25,000 miles. Tires rotated every 5,000 miles and tire pressure checked regularly.
    My tires are wearing evenly with 40/38 and it looks like I will be lucky to get 35,000 out of these.
    A Yokohama Avid S33D tire has a Treadwear rating of 320. I use a 100 multiplier for comparison purposes. So this would put this tire at 32,000 miles. Looks like it is going to be pretty close.
  6. macmaster05
    macmaster05 Senor Member
    4,050
    729
    Tire tread is subjective and varies from place to place. Take a look at the number's I've gotten;
    15k miles
    Toyota service says my tread is 5/32"
    20k miles
    Firestone says I'm at 7/32"
    25k miles
    Toyota service - 6/32"
    30k miles
    Toyota service - 8/32"
    Firestone - 8/32"
    So as you can see tire tread grows over time. :p
    My point is, I would not trust one service tech's measurement. Measure it yourself with a penny. You should literally be able to see the baldness. You should be getting at least 50,000 miles out of your tires.
    ckayte likes this.
  7. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Here are the tread wear ratings for the 15" OE Tires
    Yokohama Avid S33 - 320 (829 Revs per mile)
    Bridgestone Ecopia EP20 - 380 (833 Revs per mile)
    Goodyear Assurance Fuel Max - 540 (836 Revs per mile)
    It seems diameter (revs) are correlated to tread wear rating, which makes sense. But I don't believe they are strictly related.
    I have the Yokohamas. Seems like the Goodyear tires should last a while, but perhaps the OE version are not rated the same.
  8. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    35,000 miles for me... though with the extreme snowfalls here, sooner would have been better... especially since I found such nice replacements (Goodyear Assurance Fuel-Max). If it was summer, I likely would have went longer. Winter came at bad time.
  9. sipnfuel
    sipnfuel New Member
    1,080
    174
    So. Cal.
    Do you have the 89H or 89S speed-rated Fuel Max Tires?
  10. john1701a
    12,760
    5,246
    57
  11. Dusty Chips
    Dusty Chips New Member
    85
    Laughlin NV
    Toyota really skimps on the tires. The 2007 Corolla I just traded in on my Prius got less than 35,000 miles. Goodyears. They still had plenty of tread, but I had to get new ones when the SECOND sidewall gave out within a week. I don't expect more from the Prius tires.
    Buy Michelin....
  12. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    Those small differences in diameter would have no measurable effect of tread wear.
    Different tread wear ratings usually usually mean something within a given manufacturers line of tires but not so much between tires from different manufacturers.
  13. adamace1
    adamace1 Senior Member
    1,403
    191
    Charlotte, NC
    I have the Bridgestone Ecopia EP20 and have 38,000 on them, and plan at least 20,000 more.
  14. rrolff
    1,610
    246
    So Cal
    Are you running a 2010 Prius???
    I doubt many people can get 50K....
  15. tumbleweed
    tumbleweed Senior Member
    4,067
    687
    Eastern Oregon
    My car came with Toyo Proxis A20 (215/45-17 size). They have 39K miles, tread depth 4/32. I rotated and crossed them over once to make sure they all 4 wore out at about the same time. All 4 are worn fairly evenly but have just a bit more tread in the center than on the outsides due to wear when cornering. I have used 45 to 48 psi (51 psi max load tires).
    They have been good tires but I won't use them again because of the rip off price. I will replace them with Michelin Pilot Sport A/S from Costco or Tire Rack.
  16. Mendel Leisk
    38,874
    Totally agree.
    Break down and get a proper tread depth gauge, LOL.
    I'd set 4/32" as bare minimum, especially if you're headed into winter, and not swapping to snow tires. Would not run them down to wear bars, which I believe are at 2/32".
    Also, if the tires are nearing 5 years since date of manufacture, time for new ones, regardless of tread depth.
  17. deltron3030
    deltron3030 New Member
    437
    64
    Lakewood, CA
    reporting in with 45062 miles on the stock 15" avid tires. they've seen 20 states and all kinds of conditions, tread is just about done, though the deeper groove/ channels have about an 1/8th inch to go before complete baldness.
    getting avid envigors put on my ssr 16" wheels today, overall a few pounds lighter per wheel/tire combo over stock!
  18. cyclopathic
    cyclopathic Senior Member
    3,292
    547
    2014 Prius c
    Got 49K out of front 15" OEM Avids, rears are still on. ~38K they were almost to the bars, but then it took long time to actually get to the bars completely.
    No rotation, we usually put new on front and move old front to rear on FWD.
  19. 32kcolors
    32kcolors Senior Member
    5,683
    953
    124
    Redondo Beach, CA
    Bridgestone Turanza EL400-02 17" tires. 25k miles now (rotated every 10k miles), 8/32 front and 7/32 rear (factory recommended 35 psi front/33 psi rear).
  20. SWprius08
    SWprius08 SoCalprius
    170
    Los Angeles (SFV)
    Stock integrities, 185/65/15, factory recommended PSI. 42,000 Miles. Upgraded to Goodyear Fuel Max 195/65/15 42PSI (F) 40PSI (R). MPG improved.
