Tire wear question
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by ThePackage, Jan 24, 2010.
  1. ThePackage
    ThePackage New Member
    74
    I have almost 50,000 miles on these tires. The tires are wearing evenly but since the tread depth in the center of the tire is much greater than the outside tread, the outside tread is down to nothing. The center still measures 4/32. My questions are:
    1) will this affect wet performance, such as hydroplaining,
    2) will the tire be subject to weakness on the edges,
    3) what are the chances that Goodyear will consider the tire worn-out and honor the 80,000 mile tread warranty eventhough there is pleanty of remaining tread in the center.
    I know there are experts out there that have either experienced this issue or know someone who has. Thanks for your help.
  2. okiebutnotfrommuskogee
    okiebutnotfrommuskogee Senior Member
    1,813
    Tulsa, OK
    What were your tire pressures? Sounds like you should have run them at a little higher pressure.
  3. dogfriend
    7,512
    1,185
    Carmichael, CA
    My Integrity tires wore in this (underinflation) pattern even though I kept the inflation pressure at 40/38 or higher. If you follow the Toyota recommended pressures of 35/33 it will happen even faster.
    So far I have not heard anyone comment on getting an overinflation pattern (worn in center, ok on edges). It is always underinflation.
  4. Patrick Wong
    18,200
    6,474
    1 & 2) yes, if the outside tread is worn out, then certainly your car will suffer from low traction including hydroplaning.
    3) you'll need to visit your Goodyear tire dealer and find out. They might not honor the warranty on the basis that the tires were underinflated. However, whether the warranty is honored or not, it sounds like you need new tires.
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    I had some edge wear even at 45psi. At least increase the tp until you get new tires.
  6. ThePackage
    74
    Knowing that other people have had the same proble ios comforting and yes I HAVE been running at 42-40 (front-back). I'm curious, it sounds from your replies that this is not unique to a particular brand of tire. Any thoughts on that? Does anyone have a recommendation as to a tire which has more tread depth on the edges and performs well. I'm not knocking the performance of the Assurance TripleTred. They were great but do expect better wear than 50k. Thanks for your input.
  7. namasteflc
    namasteflc New Member
    47
    Georgetown Md
    Tire wear on the outside rather than the middle of the tire (with proper inflation) may be due to cornering the car at higher speeds. We all hate to slow down in the turns to promote our momentum and MPG, but the tire edges tend to 'roll under' the tread while cornering. With side slipping of the tires in the turns, outer tire tread tends to scuff off.
