Tires--EP422
Discussion in 'Gen 3 Prius Technical Discussion' started by cobradb, Sep 6, 2012.
  1. cobradb
    cobradb Member
    105
    tn
    i just put the ep422 bridgestone on my 2010 and i have never had a tire that i hate so much.
    these tires pull and hunt all over the road,,, anyone had this experience?
    noticed it as soon as i drove on the road ,,, after removing the ep20's
  2. a priori
    a priori Canonus Curiosus
    3,083
    407
    23
    Chicagoland (West)
    Ouch! Have you had the car aligned recently?
  3. PriusCamper
    PriusCamper Senior Member
    11,055
    4,498
    Pacific Northwest, USA
    How many miles on the new tires? Maybe after alignment and some tire wear it will improve?
  4. F8L
    19,011
    4,081
    50
    Grass Valley, CA.
    Brand new tires will sometimes do that because of deep tread and not being fully cured. After a couple thousand miles they start acting normal. Unless you have a defective tire.
  5. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    The sidewalls are fairly soft on the EP422, see alfon's recent post about the wandering on the highway. The Energy Saver A/S does the same, and it worsens as the tread wears down.
    From what I can tell, the only tires that the seem to deliver strong fuel economy while maintaining "safe" straightline stability are the OE tires. Anything else either compromises fuel economy or traction/handling.
  6. alfon
    alfon Senior Member
    1,370
    270
    seaside, oregon
    The Michelin Energy Saver tire is a superior tire to the Ecopia EP422. The
    Ecopia's seem to drift especially at 65-70 + mph speed. The sidewalls are
    much softer it seems than the Energy tires.
    I plan on returning them back to Costco, 30 day money back guarantee, and getting 4 new Energy Saver tires.
    My Energy tires had 68,000 miles when I purchased the Ecopia tires. Even with
    that many miles they seem to handle and ride better than the Ecopia tires.
    The Michelin Energy gets 2-3 mpg more than the Ecopoias as well from
    my findings.
  7. Mr Bill
    Mr Bill Junior Member
    Lee's Summit, Missouri
    I replaced my oem's with Continental ProContact EcoPlus and have been very pleased so far (6k miles). I did notice for the first 2-3k miles that my mileage dropped by 2-3 mpg and there was a 'squirmy' feel to the tires, although they felt very secure in turns and on wet roads; they are also quiet. Now that I have more miles on them the squirmy feel is gone and my mileage is about where it was with the original eom's, i.e., around 52 mpg all-around. I don't know about your Ecopia tires, but perhaps they will settle in after a few thousand miles like my Continentals did.
  8. Former Member 68813
    3,524
    981
    US
    Yes, new tires need to brake in some, but it should take a couple of hundred miles at most. If sidewalls are too soft, more pressure should fix it.
    OP: what pressure do you use?
  9. The Critic
    3,193
    2,321
    CA
    It is unacceptable for these tires to not perform at their full potential at the Toyota recommended pressures. Period.
    iPhone ?
  10. Former Member 68813
    3,524
    981
    US
    I don't think so. I stopped using "Toyota recommended pressures" in my cars many years ago as I was fed up with mushy tire response and poor cornering. Higher pressure fixed all those problems.
