Tires for 2001 Prius
Discussion in 'Gen 2 Prius Main Forum' started by ecoguy2, Jan 1, 2006.
  1. ecoguy2
    ecoguy2 New Member
    can anyone share which tires they replace the OEM tires with? Do it affect the MPG. Which Brand, model did you buy, and are there any good deals out there. Looks like a set is going to cost about $ 400.
    James
  2. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
  3. tochatihu
    tochatihu Senior Member
    9,060
    3,529
    Kunming Yunnan China
    2001 Prius
    On John's recommendation, I also bought the Goodyear Allegra tires at Sam's Club.
    I retired them early (with only about 45k miles) and installed the even better Nokian i3 in the 185/65 14 size. Because of the wider tread I suppose that 2 mpg loss (or so) might be permanent. But for the very few Prius drivers who choose to drive on unpaved roads, the Nokians allow you to substantially reduce the inflation and still have good load capacity. At 43/40 psi or so, they are very impressive highway tires.
    I still have the Allegra tires, and they still have 4 mm tread depth, but it would probably not be practical to ship them off to another Prius driver for their final 10-15k miles.
  4. Frank Hudon
    Frank Hudon Senior Member
    4,147
    I have the Dunlop SP10's that came on the 2003 and they are wearing fine. I'm thinking about 40-45,000 miles if things go as they are now. Maybe a bit less maybe a bit more but that's how things are looking now. They are LRR's like the Potenza that came on the 2k1's and 2's but way more durable.
  5. ecoguy2
    ecoguy2 New Member
    Thanks John
    So you bought them at Walmart?
    James
  6. ecoguy2
    ecoguy2 New Member
    Frank,
    Thank you for your feed back. I guess I will go to Walmart to pick up a set
    James
