Tires Michelin Defender vs Michelin Energy Saver
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by CaliforniaBear, Jan 23, 2019.
  1. CaliforniaBear
    CaliforniaBear Clearwater Blue Metallic
    1,179
    289
    Northern California
    The local Toyota Service says that Tires Michelin Defender is a replacement for Michelin Energy Saver and has the same low rolling resistance. Is that true?
  2. Mendel Leisk
    38,669
    #2 Mendel Leisk, Jan 23, 2019
    49,402
    both good tires. some people have better luck with one than another, for whatever reasons. definitely different characteristics though
    Data Daedalus and Mendel Leisk like this.
  4. CaliforniaBear
    1,179
    289
    Northern California
  5. Mendel Leisk
    38,669
    I don't think 20%. Maybe you were looking at Michelin's one-to-ten scale ratings, for fuel efficiency? Those are their rating system, and I think all you can take away from it is that they claim the Energy Saver A/S is better, for rolling resistance. I think they're true about that, but it would be single digits I think, maybe 5% at most?
    The Defender is a good all-round tire (no pun intended, lol), fwiw.
  6. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    Recent purchasers have Energy Saver A/S from a factory in Scotland, which is totally different than the ones with a good reputation.
  7. Mendel Leisk
    38,669
    How so? Quality slipping?
  8. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
  9. Mendel Leisk
    38,669
    Sounds like they're taking a page from Bridgestone with their many versions of Ecopia EP422. :rolleyes:
    Geez, I've got the attention span of a mature cucumber: see I was the first responder in the thread you linked...
  10. bisco
    49,402
    unfortunately, the energy savers seem to be hit or miss. first, finding them in stock, then, having good success.
    some report fair mileage only. some report poor tread wear. some report noise increasing as tires wear.
    i have had good success after 7 or 8,000 miles, but not enough mileage for good data
    Robert Holt and Mendel Leisk like this.
  11. CaliforniaBear
    1,179
    289
    Northern California
    Good point on the %. In any case the ES should be better than the original EP 20.
  12. Mendel Leisk
    38,669
    I bought (Bridgestone Ecopia) EP20 twice, as replacement tires on our Civic hybrid. The come in one size only (195/65R15), tread pattern never varied, and every time I put them on, brand new, mpg didn't skip a beat: excellent from the get-go.
    This reminds me a bit of one time, I was trying to buy a couple of pairs of Levis jeans, and I could not find two pairs, supposedly the same size, that fit the same. Manufacturing quality going downhill.
    Merkey likes this.
  13. Robert Holt
    Robert Holt Senior Member
    1,313
    888
    Ok, here is a relevant data point:
    Michelin Energy Saver A/S installed by Costco in December of 2014 at 39,000 miles.
    We are currently at 84,000+ miles, so the difference is 45,000 miles.
    I run them at 40 psi , and typical use is 2 persons in mixed suburban and trip driving.
    Current tread depth is 7.5-8.5/32” measured at center of tread on all 4 tires, so an average of 8/32” (or 1/4”). My tread depth gauge says that measurement is at the lower end of the “good” tread depth range, nearing the “fair” range, but that is acceptable wear, I think, for 45,000 miles.
    Our mileage hovers at 53-54 mpg year-around over these 4 years , slightly on the high side of that higher in Summer and slightly on the low side of that in Winter.
    No discernible or noticeable change in tire noise over these 4 years and 45,000 miles.
    Here endeth the data point.
    Yea Right, bisco and Mendel Leisk like this.
  14. Mendel Leisk
    38,669
    That last line alone warranted the "like".
  15. jfschultz
    jfschultz Active Member
    635
    114
    Germantown, TN
    2013 Prius Plug-in
    When I looked at tires for my 2013 PiP, I went with the Michelin Defender. While it may not be as efficient as LRR tires, according the the TireRack evaluations, the Defender is much better in wet and snow traction. I put safety over MPG.
  16. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    And is cheaper and lasts longer. I have the same.
  17. CaliforniaBear
    1,179
    289
    Northern California
    Good to know. I Never drive in snow, seldom drive in rain.
