1. nicoj36
    nicoj36 Active Member
    518
    162
    Getting new tires soon. What would you guys recommend that has the best performance and MPG for our gen 3s? Will you post brand and avg mpg?
  2. ETP
    ETP 2021 Prime(Limit),24 Venza Limit,B52-D,G,F,H
    2,803
    1,170
    Auburdale FL
    Ecopia 20s can be ordered online from Walmart and Tirerack. Pick OEM MIJ. Those are the best tires for mpg at 40-42 PSI. 42 is the answer to everything in the universe.
    Car I traded had 64K and most of the tread left.
    Make sure you don't buy a 2016 after you buy the tires.
    Goodyear Assurance fuel max at SAMs is another option.
    I have good luck with all the OEMs MIJ.
  3. Mendel Leisk
    41,900
    Costco has EP20 too. Actually most places stock, or can order them in. Good for RR, decent road feel, one of the cheaper tires, a known quantity.
    52,388
    michelin energy saver a/s, if you can find them.
    Okinawa likes this.
  5. fuzzy1
    10,603
  6. ETP
    2,803
    1,170
    Auburdale FL
    Wonder if there are any current test results? That thread seems very old. Set of Michelins wore out early on a Caravan my son has. 8 sets with poor results on numerous cars so far.
    I remember when Michelin was the best and Bridgestone the worst. Not true anymore. Hope my special order has Bridgestone MIJ like the other 2016 Touring.
  7. Former Member 68813
    3,524
    983
    US
    i love the idea about sticky threads for commonly asked questions, but that sticky is very problematic.
    the poster in the sticky included the
    Continental PureContact with EcoPlus
    based on this, i bought a set and found out they are not really LRR tires, i took a huge hit in MPG, way more that would be expected from going from old tire to new tire. i contacted the poster and he refused to change his recommendation. so, basically he helps to spread misinformation (false advertising).
    ETP likes this.
  8. ETP
    2,803
    1,170
    Auburdale FL
    Found out the hard way myself. Just assumed Michelin LRR was the best. Unless you have tested all those tires at proper inflation levels for max MPG or know a reliable site that has current test results, stick with OEMs. You could do much worse.
    At higher pressures the MIJ OEMs have a better ride than any Michelin I have ever owned.
    If you run your tires at 36PSI or lower and the car is out of alignment then you will get much faster wear. 40 PSI is my minimum as I may need to have a heavy load from Lowes.
    Even all My Honda Hybrids did much better with OEMs. If MPG is not a concern then why would you ever buy a smallish Hybrid. Get a big truck or van and run us off the road. My Dodge Caravan Touring was the most comfortable car I have ever owned. IMHO and does not reflect the views of this TV station.
  9. Mendel Leisk
    41,900
    @ETP: that's your acronym quota for the day, lol.
    ETP likes this.
  10. ETP
    2,803
    1,170
    Auburdale FL
    my favorite is MIC KEY MOUSE for manufacturing origin
  11. Mendel Leisk
    41,900
    While we were driving my wife once said: "How about we get some CD's at A&B?", "A&B" being a local record store, now defunct. Made perfect sense, but kind of cracked me up.
    ETP likes this.
  12. toyolover
    toyolover Member
    441
    67
    toronto, canada
    I purchased the Ecopia from Costco about two years ago. It is no better or no worse than the original OEM tires. In other words, a safe bet is you are not looking for anything particular in performance. I may consider a different brand only if the price is equal or less than the Ecopia.
  13. Mendel Leisk
    41,900
    Keep in mind there's more to the name than "Ecopia", there's Ecopia EP20, EP422, EP422 plus, EP100.
  14. ETP
    2,803
    1,170
    Auburdale FL
    Ditto, and all have different wear properties, MPG, and places of manufacture. I believe all EP 20s may be MIJ. TBD
    #14 ETP, Apr 20, 2016
  15. Mendel Leisk
    41,900
    Yeah according to Tire Rack the EP20 is made in Japan, and the EP422 plus (in 195/65R15) comes in 2 varieties, different tread, different wear, different max pressure, one from Mexico and one from US. This doesn't seem to be doing the company any favours, causing confusion/consternation for customers?
    ETP likes this.
  16. AzWxGuy
    AzWxGuy Weather Guy
    1,066
    547
    Tucson, AZ
    2021 Prius
    I will most likely cave and put Goodyear Assurance on my car again. They do well on the hot roads I drive on with the occasional 2 inches of standing water flash flood during the summer months or some snow flurries in the winter. I keep the pressures consistently at 42/40 and I see between 51-54 mpg. Rated for 80K miles and I have gotten exactly that twice now. I'm just not in an experimenting mood.
    EDIT: I should have been more specific as to what model or sub-brand I use. The Comfortred Touring is my tire of choice.
    #16 AzWxGuy, Apr 20, 2016
    wayne76 and ETP like this.
  17. Mendel Leisk
    41,900
    Yeah, bird in the hand is worth something. A long mileage tire with good rolling resistance, stick with it.
    In 17" our Michelin Pilots roll surprisingly well, better as they age I think. We're at 60,000 km's and 7/32" remaining tread depth. I do swap them out for snow tires in winter, so more like 45,000 kms on the Pilots.
  18. ETP
    2,803
    1,170
    Auburdale FL
    Those will work fine
  19. socal13
    socal13 livin in the foothills...
    267
    Altadena CA
    On another note, I had a blowout on the 210 freeway today (it was actually my other car, 2015 Avalon) with only 1950 miles. Bridestone Turanza el400-02, 215 55r17. Got over ok and I dont think it damaged the rim, amazingly. I'm trying to get the dealer to replace it. Talking to them tomorrow.
  20. Mendel Leisk
    41,900
    Wow! Good you're ok.
