Tires
Discussion in 'Gen 2 Prius Technical Discussion' started by Shahzad Nayyar, Sep 16, 2016.
  1. Shahzad Nayyar
    Shahzad Nayyar Junior Member
    94
    23
    Pakistan
    Hello everybody. I just got myself new set of yolohama a drive tires. They r smooth and silent. Wanted to ask what shud be the optimal tire pressure. I have a 07 vase model with 100k KM..... in our area gen there is a trend of keeping tore pressure 30.. thanx
  2. Shahzad Nayyar
    94
    23
    Pakistan
  3. exstudent
    exstudent Senior Member
    2,213
    901
    Torrance, CA
    In the US, the driver door jamb (left side of vehicle) sticker says 35fromt/33rear PSI for the 185/65 R15.
    Many on PriusChat seem to be using 40front/38rear PSI or 38front/36rear PSI.
    Your are using 195/65R15, which I think is the Touring size tire. I dont know if the Touring model Prius uses a different pressure or same pressure.
    Whatever pressure you use, measure the tire pressure when cold and do not add air exceeding the maxmum pressure written on the tire sidewall.
  4. dolj
    dolj Senior Member
    7,645
    3,858
    Wellington, New Zealand
    I had Yokohama C.Drive 2 195/55/R16 tyres in the UK, and although they are not marketed as LRR, I found them to be quite good as far as economy goes. I ran them at 39F/37R but you need to monitor the tyre wear and adjust accordingly.
    Please be aware, that tyres, even with the same name, may be different in different markets, therefore YMMV (your milage may vary).
    The important thing to do is monitor how the tyre is wearing and adjust the pressure accordingly. The correct pressure is the one in which the tyres wear evenly across the road contact surface.
    This chart show different wear patterns (take particular note of the first two columns–Rapid Wear at Shoulders and Rapid Wear at Centre:
    hope this helps.
  5. 09Prius2
    09Prius2 Member
    201
    88
    FL
    I ran around 40 on those when I had them. They have a separate inner tread pattern so anything much over 40psi will interfere with your traction and treadwear.
