TIS Loses Communication When Trying To Bleed Brakes? Help
Discussion in 'Gen 3 Prius Technical Discussion' started by Sidewayzgt, Sep 25, 2018.
  1. Sidewayzgt
    Sidewayzgt Junior Member
    Los Angeles
    My car or TIS is giving me issues with bleeding the brakes. I have had codes C1231,C1345 and C1451 for a while now. These codes have triggered the ABS light, Brake warning light, Parking brake light and Traction lights. I want to get these lights to turn off and I have read that the first step is to bleed the brakes. To make a long story short, TIS or my car will not let me bleed the brakes. It lets me connect to the car, but every time I go to the Utility screen and try to bleed the brakes, it says that it “lost communication”? I can activate and run other tests but this one for some reason will not work. Does this sound familiar to anybody? It worked before when I did my front brakes a year ago. Thanks!
  2. Mendel Leisk
    38,647
    I'm not sure what TIS is: Techstream? If you're using Techstream, maybe you reset any warning lights, and start fresh:
    It is possible to bleed the brakes without Techstream; it involves putting the car into "invalid" mode. There's an instruction for this in the Repair Manual (attached), and @NutzAboutBolts did a brake bleed more-or-less following this method, pinned in the 3rd gen maintenance sub-forum.
    My wife and I did the brake bleed about a year back, using the invalid mode method, without mishap. More-or-less followed the video, except went in the order suggested in the Repair Manual (Front/Right, Front/Left, Rear/Left, Rear/Right).
    Also, in the video they have a vacuum source, but you'll be ok without it. The only time you really need suction is just to baste most of the fluid out of the reservoir, at the outset. For the rest stepping on the brake pedal either provides mechanical pressure (front brakes), or activates a pump (rear brakes).
    Watch the video a few times, and you'll get the hang of it. I purchased two pint bottles of Toyota DOT3 fluid, and that worked out fine. I tried to be strategic, in how much I pumped out at each corner, aiming to end up with the level in the reservoir approximately the same as at the beginning, and with a little bit left over, just in case.
    scona and NutzAboutBolts like this.
  3. Sidewayzgt
    Los Angeles
    Thank you for the info. I also really want to find out how to reset those codes and get the lights to turn off (C1231,C1345 and C1451). I cannot get them to erase no matter what I do. Where do I start with those? Thank you
  4. Mendel Leisk
    38,647
    I've no Techstream experience, but it's gotta be doable. Unless there's something ongoing that's immediately causing the codes to come back. Think good thoughts.
    Found this, the codes seem to point to "clock spring", in the steering wheel?
    Prius codes. C1203, C1231 and C1345 | PriusChat
    In other words: the brake bleed might have been a wild-goose-chase? Good idea though, say tri-yearly.
  5. Elektroingenieur
    2,515
    3,258
    Three Touring
    This sounds a bit like the problem @ChapmanF encountered while trying to bleed the brakes on his 2010, which turned out to be a problem with the Vehicle Interface Module (VIM) or its software. Which VIM are you using? Can it do a complete Health Check?
    TIS is the Toyota Technical Information System website, available at techinfo.toyota.com. The Toyota Techstream diagnostic software is included with a Professional Diagnostic subscription to that website.
  6. ChapmanF
    15,435
    Ahh, C1451, the evil Motor Drive Permission Malfunction code. Yes, that's a lockout until you successfully complete a brake bleed. Nothing else clears it. (In my case, I knew I had not opened any lines, so I just faked my way through the Techstream bleed procedure without bleeding anything; each time it stopped and told me what bleed valve to open, I'd just say "sure, yeah, just did that" and click Next. Of course if you've done work on the system where there could be air in it, you would go through the procedure for real.)
    I suspect the "lost communication with vehicle" problems I was having during that bleed were the fault of the VIM that I was using, but I cannot give you proof. That VIM also used to say "lost communication with vehicle" whenever I would ask for the engine data list, and the one I am using now does not have that problem. So whenever I have cause to try a brake bleed with it, then I'll know whether the old VIM was really the problem there too. But so far, I have no desire to reopen that can of worms until I actually have to.
    -Chap
  7. Sidewayzgt
    Los Angeles
    That worked like a charm! Thank you!
  8. ChapmanF
    15,435
    Glad to hear it! But, umm, what worked?
    At first it seemed like you were asking about a "loses communication when trying to bleed" problem, and then you also had a C1451. Completing a bleed is definitely what makes the C1451 go away, but what got you past the first problem? Or did you just keep trying until one try got all the way through?
    -Chap
  9. Sidewayzgt
    Los Angeles
    The aftermarket clock spring that I bought was crap. I bought a Toyota clock spring with a new steering sensor and boom, it worked! I have 0 codes.. Last time I buy aftermarket stuff for this car!
    Raytheeagle and Mendel Leisk like this.
  10. Raytheeagle
    Raytheeagle Senior Member
    11,251
    15,481
    Bay Area, California
    2019 Prius Prime
    Might be the last time buying anything for this car, based on your new thread;).
    Good luck with your sale (y).
  11. Sidewayzgt
    Los Angeles
    Yes, I wanted it to be perfect before I sold it. Even know the lights were on throughout the years, it still drove like a champ. It is now ready for sale.
    Raytheeagle likes this.
  12. Tripp Simons
    Tripp Simons New Member
    Augusta, GA
    Would this be applicable to the Gen II as well?? I just changed the ABS module in it and I have a bunch of communication codes coming up. So bleeding the brakes will make this go away?
  13. ChapmanF
    15,435
    If it didn't matter what the codes were, they could only have one code, call it X0000, and it would mean "You have a code."
    What the codes are turns out to matter. C1451 is a code that means "I'm not going away until you bleed the brakes."
    If you have that code, that's what it means.
  14. The Critic
    The Critic Resident Critic
    3,193
    2,321
    CA
    Which interface were you using with TIS? Ever since I switched to an approved interface (Drewtech Cardaq Plus 2 or the Mongoose Pro cable) I have not had any communication issues.
    Also, these procedures are somewhat sensitive to the battery soc. Use a battery maintainer to maintain the voltage at a constant 12.6v (or higher) during this process.
  15. ChapmanF
    15,435
    TIS is the web-based online Technical Information Service (manuals and other documents, etc.).
    The Windows software that talks to your car is Techstream.
  16. ChapmanF
    15,435
    This thread got linked in a later thread about this issue, so I should add the followup I never got around to adding:
    I did, eventually, have a chance to do brake bleeding again, using a different VIM (a Tactrix Openport 2.0 instead of the Mini VCI that I was using before), and the brake bleeding went smoothly without a hitch that time.
  17. DannyK
    DannyK New Member
    Virginia
    It's pretty old thread, but there might be someone like me who is still facing this issue. Had similar problem with my mom-in-law 2010 Prius. She got C1391 error (Looks like ABS Actuator went bad). I bought chippo Mini VCI cable from amazon, installed multiple versions of Techstream (On Win10 laptop and Win XP VM etc., all configurations) but the result was the same - as soon as I hit "Bleed brake" (whether it is routine regular bleeding procedure or "bleeding after ABS actuator replacement") after couple of menu tabs it throws "lost communications with the vehicle" error and starts from beginning. The solution I found was to clear the code that was stored. After that it let me though to next steps without losing communication.
    ASRDogman likes this.
  18. Meiram
    Meiram New Member
    Usa
    Hi. I have such a big problem. Loss of connection. Which code exactly did you reset? In which window? Or do you mean resetting DTS errors. Thanks in advance for the information
  19. Meiram
    Meiram New Member
    Usa
    I have a 2011 Prius. Tactrix with Techstream v12. At the same time, the connection with the old actuator is working. But he's got a pressure leak.
