To buy or not to buy a 2nd gen Prius... Fuel economy?
Discussion in 'Gen 2 Prius Fuel Economy' started by Robert_Ireland, Jan 4, 2020.
  1. Robert_Ireland
    Robert_Ireland New Member
    Carrigrohane, Cork
    New on the forum and considering buying a gen2 Prius.
    I will soon be making seriously more commuter miles and am therefore orientating myself on a 'new' car to do these miles. My main concern is fuel economy, comfort comes second.
    I will be doing 120 miles per day for 3 days a week, hence going up to 360 miles. I will be driving from rural Ireland up to Cork city, meaning long stretches with speeds between 40 and 60 mp/h, a bit of uphill and a bit of downhill.
    Can anybody estimate what sort of fuel economy I can expect with a 2nd gen Prius, anywhere from 2004 till 2008 (this is as far as the budget will stretch)?
    I realize that I can also drive a Peugeot 107/Citroen C1/Toyota Aygo or a Corsa 1.0 with good fuel economy and lower maintenance cost, mildly lower tax and insurance, but when I can get the same or better fuel economy from a Prius, I know what I would rather be driving :)
    Any tips or links to interesting pages are welcome and much appreciated!
    49,390
    welcome!
    that should get you 50 mpg, in a well tuned vehicle
  3. Robert_Ireland
    Carrigrohane, Cork
    Thanks! I realise that there are virtually no guarantees when buying an older, second hand car, it will be a risk no matter what. 50 Mpg sounds acceptable enough for me, after all, a bit of comfort is nice when spending so much time in a car and the car can of course be used for purposes other than commuting as well :)
  4. ydpplqbd
    ydpplqbd Active Member
    542
    250
    My 2006 Prius gets 46 to 48 mpg (real world gas mileage - mix of local and interstate) in winter here in the northeast US. My mileage has improved since purchase. I attribute mpg increases in my Prius to the following: i.) new air filter, ii.) new spark plugs, iii.) oil catch can and new PCV valve, and iv.) my own better knowledge on how to drive the Prius.
    Make sure to "test" the HV battery before purchase. The HV battery test (this test is often referred to on this site but I do not know the test's origins) goes something like this:
    i.) reset MFD mpg calculations at beginning of this test (IOW MFD should now show 0 miles and 0.0 mpg at beginning of test).
    ii.) drive Prius on as flat a road as possible at 60mph using cruise control with no other electrical accessories (turn off fan, radio, lights) for three to four miles, and
    iii.) at the end of the test of three to four miles note the calculated mpg.
    If I have not stated the test correctly or accurately then please jump in and provide correction.
    The noted mpg is an indication of HV battery health. My understanding is as follows regarding mpg noted for Gen2:
    >51mpg: Prius is operating as if it is well maintained and has a brand new battery
    50mpg: Prius is well maintained with a very good used battery
    48mpg: Prius runs well with an adequate used battery
    <40mpg Prius likely has a failed battery
    Make sure that no Check Engine Light (AKA CEL) is on before the test. As a CEL will often cause diminished gas mileage and therefore affect the above results (despite the CEL often not being battery related it will often affect mpg - think misfire or bad catalyst for examples).
  5. dolj
    dolj Senior Member
    7,631
    3,849
    Wellington, New Zealand
    The only 3 things I will add is, before conducting the test:
    • Check tire pressures are 33 PSI Rear and 35 PSI Front.
    • The test should be conducted after the car has been driven for 15 - 20 minutes and is fully warmed-up and in stage 4. See the link in my signature Hybrid Warm up: 5 modes of Prius Operation..
    • If you have cruise control, use it.
    I would put this as number 1 and my number 2 would be check tire pressures are 33 PSI Rear and 35 PSI Front.
    The time of year makes a big difference. If the outside air temperature is 11ºC or less you will not get as good economy as it is above. The best economy is gained at 22 - 25ºC
    11ºC = ~52ºF
    22ºC = ~72ºF
    25ºC = 77ºF
    #5 dolj, Jan 5, 2020
    ydpplqbd likes this.
  6. scona
    scona Active Member
    225
    206
    Courtenay, BC, Canada
    2013 Prius v wagon
    A 12 to 15-year-old Prius is close to needing a High Voltage battery replacement. If you can find one that has had the HV battery replaced
    that is worth looking at. If not, any fuel savings probably disappear when the battery needs to be changed.
  7. Leadfoot J. McCoalroller
    7,135
    6,684
    Pennsylvania
    2018 Prius c
    An older Prius is definitely going to cost more to operate than the Aygo/Corsa or others listed. It's also a nicer car, I can see why you want it.
    scona likes this.
  8. Robert_Ireland
    Carrigrohane, Cork
    Thanks all for the extra information, much appreciated! It is something to take into consideration.
    I am pretty much torn still between the two, unfortunately there is no Prius for sale in the area for else I would take it for a spin to see how it drives. Not in a hurry yet, I have a car to do the miles when the time gets there, but this is far from fuel efficient :)
    Oh yeah, it is correct that the battery can be reconditioned? This is what I find online...
    #8 Robert_Ireland, Jan 7, 2020
  9. Leadfoot J. McCoalroller
    7,135
    6,684
    Pennsylvania
    2018 Prius c
    Yes. It's rather time-consuming, and you have to start doing it before it's too late, and even when you do it all properly the battery will need to be replaced.
    Get one with a known bad battery, get it for a low price, put a brand new Toyota battery in there and enjoy a decade of top performance. Costs less & drives better in the end.
  10. lexidium
    lexidium Active Member
    235
    109
    manchester
    The main thing is to learn how to drive a Prius in the correct way in order to gain the maximum fuel efficiency.
    Lots of articles on the internet about it for you to look up.
    Don't drive it how you would a normal petrol car.
    Also, as was said earlier, keep the tyre pressures correct as that certainly helps.
  11. Moving Right Along
    Moving Right Along Senior Member
    690
    540
    Average miles per gallon in gen 2 Prii are 42-44 mpg, according to Fuelly. Mine gets roughly 45 mpg.
  12. lexidium
    235
    109
    manchester
    A gallon here (UK) is equal to about 1.2 gallons in US
    My average over the week is about 58-60
  13. Classic Car Guy
    Classic Car Guy Active Member
    396
    114
    Northwest, USA
    That's about right what I get on the city.
    Last year my average was 45.7 MPG w/ a lot of freeway driving 65 miles a day using 195 / 65 / 15 tire.
    Now its 44 on city stop and go driving using the standard 185 / 65 /15 tires.
    But I don't pump my tires more than 37 psi just for personal reasons. But I heard there's a lot of people put more air and they get better mileage. Either or anything above 32 mpg is already an excellent contribution to your wallet and the world crisis.
    #13 Classic Car Guy, Jan 8, 2020
  14. dolj
    dolj Senior Member
    7,631
    3,849
    You will get exponentially less benefit going higher than 37 PSI.
    Your "better" MPG on the 195/65/15 was more than likely not real, but largely due to the slightly larger diameter. The correct proportion for the 195 mm tire is 195/60/15.
  15. roccostud
    roccostud Junior Member
    Seattle
    depending on age of the car and time of year it varies. i get between 40-50mpg ( in the usa ) my daily average speed is maybe 35-45mph
