To charge or not to charge?
Discussion in 'Prime Plug-in Charging' started by Worldbuyer, Jul 6, 2020.
  1. Worldbuyer
    Worldbuyer Junior Member
    Carlsbad, CA
    2019 Prius Prime
    I have a 2019 prime and have been charging it most nights. I've been looking for anyone who knows the ramifications of charging the batter to 100% every night. I have a couple friends with Tesla's and they only charge to 80% to save the life of the battery and rarely use the super chargers because they're supposed to be real killers. So I'm wondering does Toyota have a different kind of battery not susceptible to these issues or am I killing the life of my battery? Also if anyone has info on the impact/damage from using level 2 charger vs the standard plug the car came with I'd appreciate it. Thank you!
    Michael Wood likes this.
  2. john1701a
    john1701a Prius Guru
    12,833
    5,310
    58
    You are never charging to 100%. The value displayed is "usable" capacity, which is a maximum of 84%. That extra hidden 16% is saved for longevity. You can't ever use it, but you can see it using an aftermarket ODB-II reader with an app.
    As for level-2 verses level-1, there's basically no difference when you compare to super-charging. You're comparing 3.6 kW max for Prius Prime to speeds starting at 60 kW minimum with the dream of making the current fast 150 kW look slow in future, striving for 350 kW.
  3. Tideland Prius
    16,623
    Like @john1701a said, 100% on the battery display is 84% actual state of charge (SOC).
    Tesla is unique in that it gives the owner almost 96% of the available battery with most of the buffer at the bottom. This means it's up to the owner to charge to 80% on their own.
    Michael Wood, AldoON and Worldbuyer like this.
  4. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    If you fully charge it and then don't drive it for a few days, that might not be great in the long run. If you fully charge it everyday and then drive it the next day, that's probably not bad.
    The temperature increase is surprisingly low with both L1 and L2 charging. The only time it's likely to be a problem is charging in afternoon sun in hot weather. That's mostly because the cabin gets hot, and the car seems to circulate air through the batteries mostly/only from inside the cabin. It can use the AC to cool the battery, but only once at the start of the charging cycle, and only if the battery is already got (over 95F) when you plug in, and only if you say yes to the message that briefly appears when you turn the car off (you have to select yes every single time).
    Personally, I use the timer to schedule it to finish charging every morning by 6am. That lets it cool off in the evening before it charges. It charges at the coolest time of night, and doesn't sit fully charged all night. Electricity is also most abundant at night. I pay the same rate all the time, but it might be slightly less wasteful than charging at peak times when power comes from less efficient peak sources.
    Now that I'm not driving everyday, I try not to charge until it gets close to empty or until I know I'm likely to drive the next day.
  5. Worldbuyer
    Carlsbad, CA
    2019 Prius Prime
    New I'd find someone smart on here! Thank you so much!
  6. Worldbuyer
    Carlsbad, CA
    2019 Prius Prime
    Thank all, very helpful!
    Be well,
  7. Rob43
    Rob43 Senior Member
    1,373
    1,049
    VA, BMW Race Car, BMW R1200R, BMW 330Ci, Ford F350
    2013 Prius v wagon
    Are you currently charging up with Level 1 or Level 2 ?
    Rob43
  8. Worldbuyer
    Carlsbad, CA
    2019 Prius Prime
    Level 1, looking to upgrade to level 2 eventually.
  9. Rob43
    Rob43 Senior Member
    1,373
    1,049
    2013 Prius v wagon
    Sounds good, remember that you can use your current Toyota OE 120v EVSE unit at 240 volts. Your new charging time will be about 2:28 minutes from 0% to 100%.
    Rob43
    Worldbuyer likes this.
