To P or not to P
Discussion in 'Gen 4 Prius Main Forum' started by StarmanUK, Dec 19, 2017.
  1. StarmanUK
    StarmanUK Junior Member
    Essex, UK
    Business Ed. Plus
    Hello all,
    After some guidance with regards to when to use P[ark] - honestly I've never driven an auto before and after reading the manual I am still slightly unsure and I'd like to make sure I am not causing any unnecessary damage.
    My main example being - if I am stopped at a set of traffic lights and waiting for 2-3 minutes the manual suggests driving in D and setting the foot parking break if I am reading correctly.
    So my question is when should and should I not use P?
  2. Dxta
    Dxta Senior Member
    1,942
    769
    Lagos
    You use P when you come to stationary. I mean, if for instance you'd want to park your car, and not at traffic stops.
    You could also use park, when you're doing any maintenance on your cat. Eg, when entering maintenance mode
    Dxta
    jerrymildred and RCO like this.
    52,393
    is this a european thing?
  4. WilDavis
    WilDavis Senior Member
    2,493
    2,155
    49
    I only use the parking-brake when I park on a hill, the rest of the time "P" is quite adequate, and when stopped at a red-light I always use the foot-brake! …no exceptions, since I well remember using the parking-brake at a red-light, forgetting I'd done it (10 secs before :eek:) and wondering why the acceleration was so bad at the green-light! :rolleyes: ;)
    kithmo, jerrymildred and RCO like this.
  5. bisco
    52,393
    i would never put in in park while waiting at a light.
  6. WilDavis
    2,493
    2,155
    49
    Me too! Me too! (…oops! :oops:)
    jerrymildred, RCO and bisco like this.
  7. fuzzy1
    10,603
    This is likely one of those things where Brits and Americans must be different.
    Americans almost never put the car in Park or use the emergency/parking brake while waiting for a traffic light. But then, we may not take a manual transmission out of gear, and certainly don't use the parking brake for this either. And other threads indicate that Brits are required to do things with the clutch that I was forbidden to do in my learning days.
  8. 2k1Toaster
    6,035
    3,855
    Rocky Mountains
    Park in an auto engages the parking pawl and should really only ever be used when... parking. Any other time it should not be used. Stopped at a red light? In drive with foot on the brake. Stop and go traffic? In drive with foot on the brake. And in the Prius park is not even needed as when you shut the car down it will automatically engage the pawl and power off. Meaning pressing the power button while in drive (and speed less than 7mph) will cause the car to engage the pawl and park.
    Additionally when your foot is not on the brake, your brake lights do not illuminate. Meaning if you are stopped at a light in park, you have no visible brake lights behind you. In most of the world this is illegal.
  9. KennyGS
    KennyGS Senior Member
    1,243
    1,045
    Keystone State
    When I have to P, I have to P. This usually occurs when I'm in the car and waiting for my wife to return from a quick stop at the post office or such. Otherwise I just go straight for the power button, which powers down and in effect places the Prius into park. I also always engage my parking brake when in either P or Power-Off.
    RCO likes this.
  10. padroo
    padroo Senior Member
    2,763
    2,252
    The only time I would use park is if in a traffic jam or waiting on a train to pass and never for a red light.
    Any extended stopping situation.
    That's why they gave it the name park. .lol
  11. bisco
    52,393
    park? huh, all this time, i thought it meant pause.(n)
  12. FuelMiser
    FuelMiser Senior Member
    1,349
    929
    Monument, CO
    I do not know what the manual says, but I would only use P[ark] when I am outside of active traffic lanes, such as off the side of the roadway or in a designated "parking" area, and I want to keep the hybrid system in "Ready" mode to power accessories or climate control, while not running down the 12v battery. As long as you are in active traffic lanes, use the brake pedal to keep the vehicle from moving.
    jerrymildred and alanclarkeau like this.
  13. alanclarkeau
    alanclarkeau Senior Member
    7,045
    7,593
    near Brisbane, Australia
    " upload_2017-12-20_11-54-39.png "
    As per most replies - I've only ever used the "P" button on the odd occasions I want my PRIUS still powered up while waiting for something/someone - which was probably only ½ doz times in 18 months.
    Definitely not in traffic - I did it once when I first got Samantha, wondered why she wouldn't go into "D" - till I remembered that, unlike my previous VOLVO, I need to put her footbrake on before she'll engage "D".
    If traffic is stopped, eg an accident or roadworks, yes, maybe, but keep your mind engaged.
    kithmo, WilDavis and RCO like this.
  14. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,093
    Columbia, SC
    Wil, I used to think like this also. Right up until Mr. PoPo came looking for me because my car (which I had parked in what looked to me like a perfectly flat parking lot a couple hours earlier) had rolled backwards and came to a stop against 2 other parked cars. Not a Prius (it was an older Ford Grenade, I mean Granada). Parking pawl failure. I have never not used a parking brake since that evening. That was over 25 years ago.........geez.... how time flies.
    WilDavis, pilotgrrl and Prodigyplace like this.
  15. fuzzy1
    10,603
    Other threads have suggested that this practice is actually encouraged in Britain, so to not blind the driver stopped behind with over-bright lights. Leaving that bright brake light on, degrading night vision, was considered quite rude and inconsiderate.
    In the U.S., we have some much other bright artificial light around that this is not an issue.
    RCO likes this.
  16. alanclarkeau
    7,045
    7,593
    With DRCC, she sits quietly in a line of traffic without her Brake Lights on, unless she's the first car.
    #16 alanclarkeau, Dec 20, 2017
    RCO likes this.
  17. Sooner Al
    Sooner Al Active Member
    385
    340
    Oklahoma, USA
    2016 Prius v wagon
    I only use Park when pulling into a parking space or our garage or waiting for a long...long...long train...
    Never in heavy or standstill traffic or at a red light.
    pilotgrrl and RCO like this.
  18. RCO
    RCO Senior Member
    3,709
    5,187
    Cornwall
    It's really up to you when to use the Park button, but to clarify what others have aluded to, when in traffic and you use the parking brake to hold the car still the electric motor will continue to drive against the brakes draining the Hybrid battery. The foot brake, on the other hand stops the power to the electric motor, thus preserving your state of charge.
    Must have had explosive acceleration!!!!!
    #18 RCO, Dec 20, 2017
  19. WilDavis
    2,493
    2,155
    49
    I was born in the UK, and lived there until 1983 when I came over here (USA), I don't remember being encouraged to do what you suggest, although I suppose it makes sense! However my immediate response to anyone behind me with extra-sensitive eyes, is to invest in a pair of sunglasses - you know, just like the ones all the selebs & cool glitterati wear! ;)
    kithmo and RCO like this.
  20. Colin Jones
    Colin Jones Member
    99
    174
    Aberdeen/UK
    Business Edition
    This.
    It's actually part of the official "Highway Code" over here:
    In stationary queues of traffic, drivers should apply the parking brake and, once the following traffic has stopped, take their foot off the footbrake to deactivate the vehicle brake lights. This will minimise glare to road users behind until the traffic moves again.
    Law RVLR reg 27 - Lighting requirements (113 to 116) - The Highway Code
    When driving a manual I was taught to put the car into neutral and engage the handbrake when stopped at lights. Then take your foot of the brake. It reduces wear on the clutch, and avoids dazzling the person sat behind you at the lights, by standing on your foot brake for the entire time (which is something that really bugs me!). Similarly when driving an automatic, I still do the same thing now - stop. When car behind has stopped, engage [P] parking brake, and take foot of foot brake. Then just put in drive to move away. I only ever use the "foot" parking brake when stopping permanently.
    KV55, StarmanUK, KennyGS and 4 others like this.
